!947 ford truck
Does any body have a picture to show the locations on wood frame to cab blocks(or a web site showing location). Also is there any rubber mounts or rubber gromets anywhere when putting cab back on the frame. There is a post for a 1940-41 truck on here but i think the 1942-47 are not the same. Mine where completely disenegraded when i pulled cab. Thanks:(:-X18
i think there the same cab. mine a 1942 2 ton. seems like there might be a difference between a 1/2 ton and a bigger truck. if you want i can get pictures but only over the weekend. there a rubber pad between cab wooden support and frame. maybe 3/8 of an inch thick rubber.
Also, Here is a thread with some discussion on the same thing.
https://www.ford-trucks.com/forums/1...1-1-2-ton.html |
