Fuel Bowl Snubber Removal Difficulty
Been doing the fuel bowl rebuild on my '96, 7.3 Powerstroke E350 van, and it's all going pretty smoothly – except for this little bugger (okay, snubber):
http://i873.photobucket.com/albums/a...psd2e61630.jpg I've been following Guzzle's OBS guide: http://www.dieselorings.com/docs/OBSFuelBowlRebuild.pdf This guide says you can get the part out with a pick. But damn if I can do it. I'm afraid if I apply too much more pressure, it's gonna break! I've tried soaking it in WD-40, PB Blaster, Liquid Wrench, and Brake Parts Cleaner. Although I still can't pry it up, it does rotate freely – about 45 degrees in either direction. Guzzle's photo shows the part partially removed upward, and you can see that it has a series of horizontal lines. I can't tell if they are concentric grooves or perhaps screw threads. If they are actually threads, then maybe the part is supposed to be unscrewed instead of pried out? Another thing: mine seems to be made of metal instead of plastic, as Guzzle mentions. Poking with a pick, the piece seems very hard – harder than any plastic I've encountered. Can't be sure, though, until it's out. It isn't steel, because I tested it with a magnet. But it could be some king of treated aluminum. (The fuel bowl itself is aluminum.) Anyway, I'm stuck at this stage of the disassembly. Is it really necessary to remove this part, and either way, how do you get it out? |
Originally Posted by timmygyu
(Post 14341326)
http://i873.photobucket.com/albums/a...psd2e61630.jpg I've been following Guzzle's OBS guide: http://www.dieselorings.com/docs/OBSFuelBowlRebuild.pdf This guide says you can get the part out with a pick. But damn if I can do it. I'm afraid if I apply too much more pressure, it's gonna break! I've tried soaking it in WD-40, PB Blaster, Liquid Wrench, and Brake Parts Cleaner. Although I still can't pry it up, it does rotate freely – about 45 degrees in either direction. Guzzle's photo shows the part partially removed upward, and you can see that it has a series of horizontal lines. I can't tell if they are concentric grooves or perhaps screw threads. If they are actually threads, then maybe the part is supposed to be unscrewed instead of pried out? Another thing: mine seems to be made of metal instead of plastic, as Guzzle mentions. Poking with a pick, the piece seems very hard – harder than any plastic I've encountered. Can't be sure, though, until it's out. It isn't steel, because I tested it with a magnet. But it could be some king of treated aluminum. (The fuel bowl itself is aluminum.) Anyway, I'm stuck at this stage of the disassembly. Is it really necessary to remove this part, and either way, how do you get it out? :-drink |
The crud was pretty bad in there; I don't see how fuel was getting thru the filter. I guess this snubber leads to the fuel restriction sensor, so, while I would like to have it working, I guess it's not going to bring me to a screeching halt if it stays a bit dirty.
Thanks for the bump.:-X22 |
(Post 14341390)
Thanks for the bump.:-X22 :-drink |
You might be able to blow it out with shop air. Or don't worry about it. No big deal if you can't get it out.
pjwoolw:
Thanks, I'll think about that. Though, I can just see it shooting off into the nether regions of lower slobbovia... |
http://i285.photobucket.com/albums/l...w/CAM00803.jpg
This is what it looks like. It is plastic. Those are fins, not threads. Yours must just have crud packed around it. |
Originally Posted by 91 Dually
(Post 14350513)
:-drink |
whoops, double post...
91 Dually:
Yeah, thanks for the pic! You've been rep'd.:D |
