Attention Engine Builders
Hey guys, I'm looking for some input on rebuilding my 6.4. I cracked number eight piston. Just looking for opinions on what pistons to use and what else everyone recommends doing while I have it tore down. It is deleted already. I plan on for sure doing head studs. This build is on somewhat of a budget but I plan on keeping the truck for a long time so I want it to last.
Thanks in advance, Jamie |
What tune was in your truck when this happened,I think we are starting to see a trend here…..
Cracking pistons was one of the factors for me to sell my 6.4. It is a pretty common issue with tuned trucks. If you can stay with stock sizes, you have plenty of options. If you have to bore, atleast de-lip and ceramic coat. Give Morgan @ Midwest Diesel a call.
Originally Posted by slowmans
(Post 13980920)
Im betting its the tuning, starting to see a lot of guys running H&S on other forums cracking pistons as well…..good luck bro!
Im not trying to point fingers here just stating what I have read, others may have had issuers with other tuners/tunes. |
Originally Posted by chesterstroker
(Post 13981001)
Running the HD300. For what its worth, I wasn't pushing it hard when it happened. It just started missing and blowing tons of white smoke. Im wondering if an injector stuck open...
not saying your like this but most guys get the tuners...drive the piss out of them...they break... then it's I drove it like miss daisy all the time.. I've had my mini maxx for almost 10,000 miles...drives perfect I've stayed with the 250hp tune... just curious what's your mileage?? good luck also!
Originally Posted by UGA33
(Post 13981302)
Could be an injector. Check your blow by. That will give a good indication on what you are facing.
Originally Posted by STROKINMY'08
(Post 13981337)
(Post 13981337)
True that. Tuner forums always have their share of guys complaining that they blew their engine in some fashion, after punching a button and dumping an extra 300+ HP into the stock drivetrain. Generally followed by accusations that somehow the tunes and/or tuner is defective in some fashion. Big tunes + stock drive train + silly right foot = Trip to the repair shop. |
(Post 13981408)
I have engine pulled already. Number eight is cracked all the way across. I looked through glowplug opening with borescope. I haven't pulled heads yet to check cylinder.
lol I hear ya man.. I'm in the same boat.. slowmans kind of got me worried for a minute.. saying that a lot of hs guys we're having this problem.. I googled it seen some issues..but it was mainly guys who've turned there trucks into race trucks..any way wish the best of luck.. I found this thread with quite a few guys talking of cracked pistons/mini maxx's maybe it'll help...or one of them could let ya know Another cracked piston - PowerStrokeArmy
(Post 13981478)
So back to my original question...I'm looking for advice on pistons. Looks like coated stockers, Rudy's Diesel, and International seem to be the most common. Just curious as to which is best and why.
Check those rocker arms for wear while you are at it.
One of the reason I never ran big HP on mine. |
