Saginaw P/S pump questions.
I'm in the process of restoring my '86 F250, and it has a 6 inch lift on it, and I plan on putting some form of meaty tires on her.
I'm doing as much research I can to make sure that I don't mess up here. I've always heard about saginaw this and saginaw that. Turns out this site provides some good info... Saginaw Steering Swap - WT4Wheeling Tech I am rebuilding a 460, I may bore and stroke it while i'm at it, haven't made up my mind yet, but my questions are: 1. Every single site i've seen that mentions anything about these Saginaw pumps, they all seem to be meant for 5.0/5.8 motors. Will this pump work on a 460? Or is there a different pump I should use? 2. With the more powerful motor, is that going to affect pressure? 3. Will the Saginaw pump work with a stock steering box, or do I need a different box? Thanks for the help guys! |
I'm not sure what your asking - It's the same pump for 5.8 or 7.5L.
Originally Posted by CountryBumkin
(Post 13532928)
You need the bracketry for a 460.
Look for a V-belt E350 van with the 460 engine. They were pretty common. The boss that bolts to the head is ~3/4" taller for the Saginaw. They work fine with the stock steering box. I used the van pressure steering line and bent it to fit. The return hose needs to loop behind the pump because of the angle the return nipple is soldered to the reservoir Be sure to wrap it to protect from chafing. If you need a pic or something let me know. |
X2, anyone who wants to do this, just find an E-series van with the same engine you have, and swap everything over.
ALL E-series vans used Saginaw pumps for all engines and years. |
Originally Posted by ArdWrknTrk
(Post 13533187)
Look for a V-belt E350 van with the 460 engine. They were pretty common. The boss that bolts to the head is ~3/4" taller for the Saginaw. They work fine with the stock steering box. I used the van steering line and bent it to fit. The return hose needs to loop behind the pump because of the angle. Be sure to wrap it to protect from chafing. If you need a pic or something let me know. |
Oh, you'll definitely need a crow's foot and a long extension to screw the pressure line into the box.
(Post 13534060)
This is the mount to the head.
http://farm9.staticflickr.com/8261/8...8dc9da7c7e.jpg Pumps, side by side. http://farm9.staticflickr.com/8539/8...1d70b73957.jpg http://farm9.staticflickr.com/8546/8...58be5db9a1.jpg The Saginaw bracket, any why it needs the taller boss. (this is without A/C) http://farm9.staticflickr.com/8393/8...e0bef95102.jpg http://farm9.staticflickr.com/8245/8...558a0dd5dc.jpg The 71202 line I used after bending it to fit the truck frame. You need to do some clocking. http://farm9.staticflickr.com/8380/8...a654974fbc.jpg http://farm9.staticflickr.com/8525/8...fd04efe377.jpg The different fittings of C2 and Saginaw pumps. This is why you can't use the trucks C2 pressure line. http://farm9.staticflickr.com/8533/8...d604eed4de.jpg http://farm9.staticflickr.com/8379/8...5eee62118d.jpg Installed. The loop on the return and the anti chafe on the hose behind the bracket. http://farm9.staticflickr.com/8396/8...3233510c83.jpg http://farm9.staticflickr.com/8529/8...3c31d5ceb9.jpg http://farm9.staticflickr.com/8395/8...5cc9475ce1.jpg Hope this helps. |
(Post 13534071)
If you have A/C in your truck the bracket will be a little different.
There will be a 'shelf' on top to mount the compressor. |
nice write up:-drink
