1993 Bronco engine wont idle
I have a 1993 bronco, that the engine will not idle on. When I give it gas. it backfires and has no power. Funky smelling smoke comes out of breather and the dip stick, when you put a rag over them there is oil on the rag. we did a engine flush, it helped but did not fix the problem 100% still acting really rough any ideas?
Thank you, Ornonic |
Clean or replace the PCV (valve) for starters, if that doesn't solve the problem at least partially then I've got bad news for you... a ring has probably failed, you should also inspect the spark-plugs to see if there is any oil there (which I suspect from the misfires you report).
