1978 - 1996 Big Bronco
1993 Bronco engine wont idle
Old 09-07-2013, 01:01 PM
Ornonic
Ornonic is offline
Ornonic is starting off with a positive reputation.
I have a 1993 bronco, that the engine will not idle on. When I give it gas. it backfires and has no power. Funky smelling smoke comes out of breather and the dip stick, when you put a rag over them there is oil on the rag. we did a engine flush, it helped but did not fix the problem 100% still acting really rough any ideas?
Thank you,
Ornonic
Old 09-07-2013, 08:13 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Clean or replace the PCV (valve) for starters, if that doesn't solve the problem at least partially then I've got bad news for you... a ring has probably failed, you should also inspect the spark-plugs to see if there is any oil there (which I suspect from the misfires you report).
rjhesseltine
1997 - 2003 F150
06-01-2015 09:01 PM
danny2313
02-10-2014 08:56 PM
calicojack
2004 - 2008 F150
20
01-06-2014 05:49 PM
eduardo
10-11-2005 12:05 AM
oft
Garage & Workshop
11-18-2002 10:13 AM
Quick Reply: 1993 Bronco engine wont idle
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
