EGT probe... Downpipe or manifold??
which is better and more accurate? heard mixed reviews for each
Exhaust manifold. Next best is in uppipe just after connection at manifold.
Bottom rear of the drivers side manifold is supposed to be the best place to put a single probe for an average of both banks. It's also an easy spot to get to for drilling.
https://www.ford-trucks.com/forums/p...ctureid=115906 |
I would due manifold before the up pipes. More metal to thread and seal better.
Originally Posted by binuya
(Post 12989397)
https://www.ford-trucks.com/forums/p...ctureid=115906 I have to disagree..that is the best place but for only dr side bank..1 EGT is good for watching over all engine temp on a good running motor, If you have an issue on the passanger side, you will never know (ask me how I know).. Personally I suggest 2 EGT gauges, one on each side, installed in the manifolds.. |
Originally Posted by joeyd61
(Post 12989436)
Put it in the manifold. I originally had mine in the down pipe and it was 2-300* cooler in the down pipe so you have to allow for that, and your guessing at best.
Jim. |
Manifold..... I've got my second egt gauge in the mail now for the driver side.
Man up... man.
might seem stranger, but what about the babyies but area?
I understand most of you can't access that area like I can, but that is where they both come together before the exhaust??? just a random thought. I can't afford to have two right now anyway let along space in any mounts I plan on getting. |
Originally Posted by MTDewX
(Post 12990615)
