Check out this Factory 1964 F250 Dump Box
I just had a guy call me about a one owner 1964 F250 he is selling, says his family custom ordered it from the factory with a dumping box. Here is the ad on a local classified site.
1964 F250 Classic - Castanet Classifieds |
Originally Posted by Hillbilly63
(Post 12929535)
I just had a guy call me about a one owner 1964 F250 he is selling, says his family special ordered it from the factory with a dumping box. Here is the ad on a local classified site.
1964 F250 Classic - Castanet Classifieds If special ordered from FoMoCo, Warranty Plate DSO code will have SIX digits, denoting a Domestic Special Order. After it left the assembly line, FoMoCo sent it to an outside body maker to have the pickup bed modified to dump body. If a part related to the dump body failed, there would be no listing for it in the Ford truck parts catalog. Dealer contacts FoMoCo, passes along 6 digit DSO. FoMoCo looks up the order number, passes the info back to the dealer saying where the parts can be found. Same DSO system used today. |
Never seen or heard of them coming from the factory this way. Possibly sold as a regular truck then taken to a conversion place like crown or coach to be made into a dump bed?
I agree, definitely not "factory", more than likely local truck shop modification.
Looks pretty interesting.
Originally Posted by markzieglerinsd
(Post 12931975)
C4TZ-9940700-A .. Styleside Tailgate-Large FORD block letters: 1964/66 F100/250 2WD, 1966 F100 4WD.
September 1966: FoMoCo obsoleted C4TZ-9940700-A, replaced it with the 1967 (1967/72) F100/350 Styleside tailgate (C7TZ-9940700-A) for use as a "service part replacement." All the mounting hardware is the same, but 1967/72 Styleside tailgate has smaller FORD letters surrounded by a raised ovate scallop line. Warranty Plate, VIN same 1966/68 US/Canada / 1965 and earlier Canadian VIN's, Warranty Plates, codes stamped on them are different from US trucks. VIN examples: 1965 F100 assembled in US: F10DR639896 / 1965 F100 or M100 assembled in Canada: 4991014L-123456-A |
N.D. Do you know if the Mercury tailgates for 67 and 68 had the raised part in it? I have not seen one with it..maybe I'm seeing only the early ones.
Originally Posted by F&M
(Post 12933205)
Whiz over to mercurypickups.com and see if there's 1967/68's pictured. |
