KOER codes
Wanted to see how the new motor is doing after breaking it in and I decided to pull codes. Got mixed results with the KOER tests...
Test 1 - KOEO - Codes: 10, 11c,11o Thoroughly warmed up vehicle Test 2 - KOER - Code: 14c Cleared codes in KOEO mode Test 3 - KOER - Codes: 13r, 24r Cleared codes in KOEO mode Test 4 - KOER - Codes: 13r, 23r Test 5 - KOEO - 10, 11c,11o Questions:
Truck runs fine on the road, not as if it's missing the RPM calculation or anything. I don't see the check engine light come on while driving. |
Are you counting blinks or using a code reader? What computer did you use for the mass air conversion?
Originally Posted by EPNCSU2006
(Post 12929067)
The reason I ask is that the 10 is not a valid code and you got something different each time. Might be worth running it once counting the blinks visually too just to double check the reader.
EEC IV Self Test hookup |
I found this:
SEPARATOR PULSE The separator pulse is a single pulse that indicates the END of hard fault codes and the BEGINNING of memory codes. It will show up as a code 10 on most digital testers. Ford Bronco EEC IV That's what it is for my code reader... |
