Van turbo questions
Ok, I have a van turbo with an ATS compressor housing, it is going in my OBS along with the manifolds and bellowed up-pipes. My question is how big of an injector will this turbo support? and what is the max boost I should push through it?
Thanks, P.S. I know that you guys have more knowledge on the van turbos, that is why i posted here instead of in the OBS forum. |
Ian the van turbo is basically a obs turbo
The van turbo wheel has a 76.20mm inducer and a 69.84mm exducer (84 trim). OBS truck Turbine wheel inducer diameter: 76.2 mm Turbine wheel exducer diameter: 69.84 mm (70 mm) |
ok, I wonder what the ATS housing does for it...
Originally Posted by plgebbia
(Post 12854223)
I can't speak from an OBS perspective, but I wanted to point out that a wicked wheel did not cure surge for me, but a van turbo with ported compressor housing is virtually impossible to surge. The larger exhaust housing on the van turbo will help manage egts on the top end and also aid in turbo life. I'll be curious to see what people say with regards to your question about injector sizes, but I will tell you that there are guys here pushing 450hp with a van turbo.
What size housing is the ATS ?
Originally Posted by fordpride
(Post 12854380)
What about max boost? Is it still 30psi or can they handle 35 all thte time?
