Antenna advice
06 Navi has a Alpine double din the radio gets awful reception lots of static and only picks up a few channels. The antenna is hooked up to the head unit and the connection near the fuse box is good. Any after martket antennas you guys recommend. Or reason why the window antenna isn't working well?
Originally Posted by wastingas
(Post 12564258)
1. It could be a bad head unit. 2. It could be a broken antenna wire. |
The stock antennas usually work better than aftermarket. May be just some bad wiring like mentioned above or possibly some interference from another unshielded cable?
(Post 12564258)
I have never heard of this.... Kinda sounds like a muffler bearing if you catch my drift. Ill take a look though. Thanks
(Post 12573523)
You know how I know... I had to do the same thing. Never a muffler bearing... maybe a wood stretcher though. |
