removable door hinge pins
I was just wondering if anyone has replaced the door pins with removables to take the doors off, jeep style?
Sounds intersting....any ideas anyone?
that would be kewl. only problem you might run into would be if you had electric windows and locks . you would have to install some quick release for the wires going to those and also for your speakers. but it could be done.
good luck later |
i have herd of it being done to broncos(yeah duh) and plan to convert mine soon. what i plan to do is get some general wire plugs from like radio shack and some long grade 5 bolts to replace the solid pins that hold the door. my friend did it to his truck............its awsome.... my turn!
Please post the steps when you get done, or bvetter yet, take pictures!!!!!
QUOTE:Originally posted by Kemicalburns only problem you might run into would be if you had electric windows and locks . you would have to install some quick release for the wires going to those and also for your speakers. but it could be done.
The Electric windows / Powerlocks have a quick disconnect located in the kick panels to the left and right of the cab down by the footspace. All you would have to do is make quick connects for the speakers |
Originally posted by Steve_Uzi QUOTE:Originally posted by Kemicalburns only problem you might run into would be if you had electric windows and locks . you would have to install some quick release for the wires going to those and also for your speakers. but it could be done. The Electric windows / Powerlocks have a quick disconnect located in the kick panels to the left and right of the cab down by the footspace. All you would have to do is make quick connects for the speakers you probabley just need a 12V pos. the doorlocks and windows can work on the same lead. althogh if you run door speakers you'll need atleast a 3 connector. |
hey does anyone know if this is illigal?
The connectors are called "Jamb Tac" in the Jeg's catalog. They have 2, 3 and 4 wire connectors, with the 4 being $24.99.
As far as legality, I'm pretty positive that here in Florida, it is illegal to drive any vehicle without doors. Unless it comes factory like that, such as a dune buggy or sand rail. Even though Jeep doors are removable, they have to be installed to be street legal. |
I did this on my fullsize f-250 and you can't beat the visibility. I love it. I have driven through town and cops have seen me and I have yet to get harrased.
I went to advance auto and bought a door/hinge repair kit with the brass bushings and I ground down the splines at the top to keep the pin from being stubborn. I am about to weld a metal rod on the top or something of the sort to act as a handle. I just pull the 2 pins, throw my door(s) in the bed and go. I relocated my door speakers to the supercab part and I have manual windows/locks so I am good to go. Happy Wheelin -Jason- |
There is no law mandating doors on a vehicle. Otherwise, Jeep owners nationwide would be locked up. .........Hey that gives me an idea....hehehehe!
Just check on the placement of your sideview mirrors....I beleive there is a law that states you have to have at least a left side mirror.
yeah i just relized the mirrors part of it, i think ill just try and find some place to temporarly re-locate the drivers mirror for when the doors off
LETS SEE SOME PICTURES!!!
Ryan |
Originally posted by jojo_3838 yeah i just relized the mirrors part of it, i think ill just try and find some place to temporarly re-locate the drivers mirror for when the doors off I'm going to take mine off tomorrow and see what i can fab-up. I'll take pictures and post them see what you guys think. |
