1999 hub bearings mileage ??
I would like to know how many miles have some of you gotten out of your hub bearings. I have a 1999 f350 four wheel drive crew srw with 105,000 .They still are tight and quiet. Leaving on a 5000 mile trip soon should I replace before I go? Your input would be appreciated.
I got 158k out of mine and I was in there doing ball joints so I just changed em out while I was in there. I wouldnt worry about them. If your concerned maybe get them and take them along just in case. That way if you have an issue with them ( if your luck is anything like mine) you are prepared.
Mine were at 180K and still going. I replaced my ball joints and bought new hubs while everything was already torn down like racincowboy did. I figured at 180K an ounce of prevention is worth a pound of cure (and another 4 hours of labor) if they died shortly after putting everything back together.
I have read where people pull the ABS sensor out of the hub and sqeeze some grease down there to keep them lubed up. |
ive got 280k on mine and checked the 2 days ago there still tight but im getting ready to do ball joints agian and will probbibly do them any way . but you got a lot of miles left (stock tires? no water crossing?) if they are tight and quite i would say no worry take trip.:-X22
I'm at almost 290K on one and around 150K on the other. I lube the bearings through the ABS hole occasionally.
I'm at 208K on one and around 80K on the other. I, too, lube the bearings through the ABS hole.
However, unless the O/P's '99 was a high-end truck (Lariat) with 4-wheel ABS, I believe it doesn't have the ABS sensor holes. Pop |
210K miles on the front, 258K miles on the rear bearings. Did the rears last weekend.
If you don't have front wheel ABS and are going to be replacing your hubs get the ABS hubs so
you can lube the bearings. The ABS sensor holes can be temporarily plugged between lubing. Fortunately my E99 XLT has 4WABS. |
I have 313,000 on my early 99. Replaced ball joints once , never touched the bearings.
291000 on both, but my pass. side has started throwing the ABS light so that will go back to zero next weekend:-roll
Thanks Guys, I have run 315/75/16 tires since 45,000. I do not have abs. When they start making noise, will they run for a while before they fail? I will pick up the parts and carry them with me.THANKS again!!! :-X22
