Bad PCM?
I'm wondering if I have a bad PCM. My truck (01 7.3) will run fine, but then just shut off momentarily. Sometimes it will start up and run 3 seconds, sometimes 120 miles. I've changed the Cam sensor, fuel filter, swapped the idm from my other truck, all to no avail. I've read that sometimes the cam sensor signal can get lost in a defective PCM. I've checked the valve cover connections, and they are good. My only other thought is a possible intermittent cps out of the box from NAPA? Help!
Haven't heard any good words about the Parts Store's CPS. Pick one up from Ford or International. You should be good to go.
Originally Posted by Mowing Man
(Post 11552813)
Is there a way I can test a cps with a meter? If so, what resistance or voltage should I get?
Have you concidered cutting your loss and maybe trying another truck?
Originally Posted by Grapevine Ford Junky
(Post 11553222)
(Post 11553222)
(Post 11553124)
I think an '01 you can still see the tach move on the dash if it's working I know on '02+ you cannot though. Usually diagnostic tool that can view live data to watch RPM signal. If it is an intermittent as you say though it would be tough to catch it with a meter until it is failing. |
(Post 11553257)
Just got this truck. It runs great, just a matter of figuring out what causes the problem. Even changing out the pcs is a few hundred dollars. Cheaper than a new truck.
Thanks Big Al. Do you think I could borrow the PCM from my 02 7.3 and try it in my 01? Would I be taking a chance at ruining my PCM in my 02?
(Post 11553222)
Have you considered cutting your loss and maybe trying another truck?
"Have you considered cutting your loss and maybe trying another truck? " http://www.fairfaxunderground.com/fo...edTheTroll.jpg Obviously a troll. Only one post and it's something stupid. Mowing man, Get a cps from Ford or international. Even if it doesn't fix your problem you'll have a spare. If it does then it's a cheap quick fix. |
Thanks guys. I'll grab one from Ford this morning and see what happens.
So I swapped out the Cam sensor today with a Ford one. Didn't change anything. A few notes that may or may not affect or cause the problem, but here is the info. A few weeks ago I blew a H.P. Oil line, which I replaced. While doing that, I broke a fuel fitting going into fuel bowl. I ended up replacing the fitting and the fuel lines that feed and return the fuel. Thought I did a good job of snaking them through and cleaning any crud off of them, but maybe not. The truck started and ran great for 2 days, and then this current problem. I have checked valve cover harnesses, they are good. I have tried 2 cam sensors now, it is good. I have changed fuel filter 2 times. First time there was some oily mud in the bottom of the bowl. I cleaned it, and it ran great for 100 miles, now back to the same. The bowl is spotless inside. I have also swapped the IDM from my other truck, no difference. When this truck acts up, it throws a po 344 and a po 340 code. It also runs on the odd cylinders, but not even ones. I can unplug the valve harness on that side it runs the same as plugged in. Harness has right amounts of resistance though, and the return wire is good. I'm wondering about my IPR. Also, only does it when warm. Any thoughts?:-X16:-arrgh
(Post 11565807)
PO344 = CPS circuit intermittent
PO340 = CPS circuit malfunction Unplug to CPS check and clean the connection. |
