S/D to MAF?
I would like to upgrade the current S/D to an MAF system. I have a 1995 f150 4.9L f/i with the e4od. I understand that the 96' series came with MAF stock and had the upgraded OBDII system. Now i have heard of some people being able to upgrade the system. But had a few questions i would like answered.
-Should i keep OBDI and add the MAF? -or Should i find a 96' take out the ECU and the MAF system and add that to mine? -What's the cost effective one? and It would also be easier to read the codes on the truck with the OBDII or should i stay away from that system? - If i did get the ECU from the 96' with OBDII would it bolt right up and hook right into everything? |
anyone with suggestions? or write ups to point me in right direction??
What is the reason for doing this? tuneability? performance? if it was for that i would opt for a megasquirt stand alone set up.
