I read that link... doesn't he contradict himself?
I dunno.. now I'm really confused. I know for a fact, the 12v Snap-On one and Craftsman 12V adjustable timing lights are not working right on my 6V car. But they are working fine on my other 12v stuff. That much i do know. So where does this put the dwell meter? Had the same problems with it too. May have to comb the swap meets next year for some old 6v tune-up tools.... |
Originally Posted by Dano78
(Post 11113803)
I use my old Craftsman timing light on 6V stuff.....it seems to work fine, just not as bright of a "flash". The easiest way I've found to set timing is with a vacuum gauge. Using MANIFOLD vacuum with the engine running at proper idle, vac advance plugged off, advance dist to it's highest vac reading. When it starts to stumble, back it off 1-2 numbers. Works on my flatty....
Yep, used the vacuum method many times over. Didn't on the 6, last time. May have to try that one too. In the past when i've swapped in much larger cams and changed induction setups I would set them quite differently.
(Vehicle must be an automatic)I'd chock the wheels and have a buddy anchor the brakes, and put the car in gear. Standing to the driver's side I'd run the throttle bringing it up to full stall (varies depending on the stall of the converter -around 2000-3000 rpm) and roll the distributor back and fourth till I get max advance without any pinging from the engine. Doing it this way has given me amazing results, but it is a little dangerous and you really have to trust your buddy helping you not to let off the brake!! :D |
A small bite out of the elephant...
I got a box-o-parts with the truck. A couple of taillight assemblies were in there, and I decided to use two to make one. The one I think is the original is in pretty bad shape, so I want to use the newer one.
Original http://i285.photobucket.com/albums/l...g?t=1324343114 Replacement http://i285.photobucket.com/albums/l...g?t=1324343114 I removed the mounting arm from the original and after cleaning it up, installed it on the replacement. http://i285.photobucket.com/albums/l...g?t=1324343114 http://i285.photobucket.com/albums/l...g?t=1324343114 And here's what it looks like on the truck. http://i285.photobucket.com/albums/l...g?t=1324343115 http://i285.photobucket.com/albums/l...g?t=1324343114 |
"New" front bumper
Got my new bumper from Josh Madsen yesterday. Had to set it in place for a photo op. I think it makes the truck look better even before cleaning it up.
Betsy with Christmas decorations and her new bumper. https://cimg0.ibsrv.net/gimg/www.for...8bc5ad694f.jpg After sanding and primer. I ran out of daylight before I could paint it. Looks great for a 60 year old bumper. https://cimg1.ibsrv.net/gimg/www.for...2cac0e3b95.jpg I may get it painted and installed next weekend. But taking down Christmas decorations may take precedence. I got lots of truck parts for Christmas, so I'll add more as I get them done. :) EDIT: I moved the pics in my Photobucket album without thinking it would screw up the links here. Well, Duh! SECOND EDIT: Photobucket wants to rob me of $60 a year so I can put pics online. So I moved them to my computer and reloaded them. |
Man that looks great. What color you gonna use?
Originally Posted by speedyweasel
(Post 11200540)
bumper looks great! I need one of those for my coe....
Originally Posted by tinman52
(Post 11200569)
That can't be a bumper.....
...a real bumper would be bent, dented, and twisted up like a pretzel....LOL That looks really good Bobby |
Originally Posted by Jolly Roger Joe
(Post 11200583)
Is the COE bumper the same as the large trucks? I think I read somewhere on this site that it is.
Looks great... Shop around I love mine
http://i1222.photobucket.com/albums/...r/DSCN1363.jpg Planing on doing the running boards next and the wing window frames next... Haven't had luck finding a rear bumper yet.... So still kicking around trying a front bumper as the rear bumper |
COE bumpers should be the same as F7-8 trucks.
Originally Posted by 51PanelMan
(Post 11200670)
