cam gear broke off 460 while installing
I was installing a new gear drive on my 460 and while i was torquing it down the portion that the cam gear rides on broke off in my hand with the gear before full torque. There is about a half inch of thread still going into the camshaft so i was wondering if this has happend to anyone else and they have a fix for it. I just got the engine together and would hate to replace all the gaskets, cam, lifters for something so small. I understand what can happen if i loose the gear under load but there is a grade 8 bolt holding that sucker on and i still have about a half a inch of thread going into the cam does anyone think this will work? Or should i just cut my losses and replace the cam to be on the safe side?
I'd replace it.
I'd like a pic of that.
I don't understand. The end of the cam broke off? |
yeah the end that the cam gear bolts up too. The gear rides on it outside of the block.
http://http://performanceparts.com/p...s_34-703-9.jpg
This is just a example but in the lower left corner at the front of the cam is what the gear slides onto and then gets bolted down thats what broke off. |
I feel for ya man.
That sounds like something that would happen to me! The worst part is - just getting close to firing it up and then BAM! a rock drops out of the sky. Good luck! |
I feel for ya man.
