EGT probe location
So last night i was doing so reading and dug up some old (2004) threads about pre and post turbo mounting locations for the egt probe.
The biggest reason put forward from the post side was what if the probe breaks off and goes through the turbo?? I did a bit of searching and coulnd not come up with any first hand accounts of this happening. My truck is stock and will stay that way until it is off warrenty so I'm not too worried about melting a turbo BUT I figure if I have paid the money to put a probe in my truck it should be in the most acurate spot. So I guess my question is this. Anyone have one of these things break and go through your turbo?? And is the risk of this happening great enough to give up an acurate reading pre-turbo. Thanks Hilgy |
I have yet to read of one breaking and going through the turbo. I wouldn't recomend putting it anywhere but pre turbo, in the exhaust manifold on the drivers side.
Originally Posted by texans
(Post 10214388)
Looking forward to doing the install this weekend. Thanks Hilgy |
One of the forum member here Mike Chan, has told me he has seen many people putting them in the Drivers Exhaust Manifold apparently you can get to it from underneath the manifold and lowering the risk if your doing it while still on the truck to get metal filings in the turbo.
I would recommend using going slow and then just as your about to go though put grease on the bit so it hold more metal. Also I would recommend using a unibit its easier to keep clean and control of the metal shavings. Currently mine is installed post turbo about 3" from clamp thats on the rear of the turbo. I plan to add another gauge in the manifold as well so I have two reference points to monitor. I plan to add my second one this weekend if the rain they are calling for doesn't happen Ill post pics of the setup. |
i would go pre turbo all day long!! and grease the bit before you even start drilling. it acts as a lube for the bit and catches most of the shavings. then take a paper clip with a magnet on the end and fish out all of the small shavings. then put grease on the tap and tap it out. then do the same procedure with the paper clip and finally install the probe.
thanks guys,
Never heard that paper clip trick before. I have a small flexible magnet that i was going to use as well as the vacum. I guess unless i find a bunch of info about probes breaking off before the weekend thats where its going(pre-turbo) Hilgy |
i have a small flex magnet too but it didnt bend enough for me so i compromised with what i had layin around. but then again i never thought of the vaccum either! guess we both learned something today haha
I have heard that some people drill the hole while the engine is running. This way, the cuttings are blown outward(?) by positive exhaust manifold pressure. Anybody else do this, or did I dream it up?
I've installed several thermocouples in DS exhaust manifolds, and never use grease or run the engine. Just work your way up to the final hole size with a few good, sharp bits. A good bit will cut the cast iron so that it comes off in ribbons. Any small pieces will fall to the ground. After you tap the hole, you can float a magnet underneath the manifold and drag anything inside, out the hole.
X2 the bit is made to extract the iron out no grease is needed but a good pair of glasses are, start small and go up to the right size i did use the paper clip works well but keep the motor off because anything that brakes off inside will go right into the tubor then when you tap it only go 1/2 way so it will fit tight when you screw it in.
http://www.dieselmanor.com/diy/PSD3-gauge/image24.htm |
Originally Posted by Dieselpop
(Post 10217761)
http://www.dieselmanor.com/diy/PSD3-gauge/image24.htm Thanks for all the comments guys Hilgy |
Originally Posted by -Hilgy-
(Post 10217991)
I take it you mean only tap 1/2 the thickness of the manifold? Approx how many threads would there be holding the probe this way?
(Post 10217991)
X2 right on
i use grease for security!! id rather be too careful then not careful enough. plus it keeps the bit lubed so that it doesnt wear out as quick. all it takes is one wrong move to dull out a bit or better yet break it off. thats why i use grease but its up to you
