Update on Benchwork steering conversion
Well so far so good. Everything has bolted right up. I have the front clip off doing a 460 conversion as well. So I have the box, adapter, steering shaft and pitman in. The only real work in it so far has been painting the pitman arm. Tomorrow I'll try and ream out the knuckle and mount up the drag link.
http://i877.photobucket.com/albums/a...5/b6fa9137.jpg |
That thar is purty. After all is said and done, let us know what your overall impression of the company, customer service, their product, and whether they did their homework. Lastly, the "up-front cost to driveability value" ratio and whether you'd do it again.
Well I'll tell you there customer service is exelent. I ordered the wrong pressure line. I have a Saginaw pump. I sent the line back and they sent it back with the correct adapter free if charge. In less than a week total time from when I mailed it back.
Steering f250.
Saw your post, how does that steering from Benchworks work? Any good? I want a kit, but waiting on advice. Thanx!
IMO that kit is a rip-off, they charge you $1,100 for parts that you can buy over the counter for a few hundred bucks.
If that isn't bad enough the kit doesn't even come with a 4X4 steering box! it's a 2WD steering box! Save yourself nearly 1K and do the power steering conversion using your own parts. |
steering conversion
2 each their own, engine bay looks real nice.I went with the 78,79 4 bolt PS.Boxed in frame 3/8 steel 5"x12", schedual 80 spacers,9/16 grade 8 bolts,on outside of frame5/16 5"x10" plate steel,Sent steering Box to Red Head steering for rebuild,Im under 500,but I did also go with the Borgesen to up grade the steering shaft.Again your truck Bay looks real nice congrats!:-X22
on another note
but waiting on advice. I would not be anywhere with this truck if it wasnt for the good folks of FTE,numerous help long list Montana HB,HIO Silver,ND,F350Ed,Fordtrucknut,MikeO,Buck,to many to list.reserch do homework,I actually thought about kit a year ago,but trying to diversify funds.springs ,axles,you know. Nothing against the kit though.:-huh:-blah
Originally Posted by Johnnyrocket72
(Post 11952618)
steering
cool steers with one finger that is awesome!:-X22
the Ford F250 Conversion kit is awesome i love mine. they know what they are talking about when i talked to them. yes it is expensive but the boss explained to me that the intermidiate shaft is made with spicer U joints and yokes and the box is a factory ford box and the backet is straight bolt on and cnc plamas cut. i would put hands down on their kit
Power steering
Hey thanx! I am going to order a kit soon. Probably in January. I need to call em before u order cause I'm going stuff a Cummins under the hood of my 73 F250. So I'll need a diff bracket for power steering pump. Thanx again though bud!
Its so pretty.
yea no problem. theyre very awesome at responce time and they helped me through the whole install. just tell them what you are doing and i think they have saginaw pump brackets for any FE Block 360 390 400 440 and 460. i got referred to them when my buddy did a convertion on a c10 and they have brackets for 350s. i wouldnt doubt if they have one for a cummins
Thanx again Adam. If they don't have the bracket, I'm prepared to make my own. I have all kinds of metal around my shop. I just rather buy one. I have to many things to build otherwise.
Buyer Beware
Done With This
