Originally Posted by topmoo
(Post 17905959)
A 1/2" at the bottom could change pretty dramatically with a small amount of tweeking at the hinge. Similar to pivoting a 20" stick/board/piece of anything a 1/16" at one end - the other end will move much more than 1/16".
Suffolkman you are right, I thought you were talking more about the gap which is 2 plane up and down. Not sure the Ford shop manual process will help with what you have. Sounds like your door is warped probably due to a past wreck with either a warped door or a cab problem. Good luck with it.
Every F1 I've come across has this problem, the pass. door shuts tight while the driver door hangs out an eighth to a quarter inch. I think it has to do with all the flex in the stock frames, you just don't realize how much the frame twists up on the right side especially with a more powerful engine. Look at the margins where the lower fenders meet the rails just behind the bumpers, most of the f1s' I've looked at have different gaps from one side to the other, all this due to frame flex. This in my humble opinion of course.
Originally Posted by F1 coyote
(Post 17907197)
