Purging Air from Cooling System-'01 F250
Is there a certain procedure for installing new coolant and purging the air from the cooling system? Just changed the water pump. Truck is a 2001 F250 SD Powerstroke.
Also new temp sensor not working (no movement on the idiot factory gauge needle, reads cold). perhaps a "bad" new one sold to me. Any way to test sensor or wire harness? Any help is greatly appreciated. J |
It will purge by its self, you don't need to do anything except maybe turn on your heater.
Originally Posted by Riffraff Performance
(Post 10053218)
Also, don't forget to check your coolant level once a day for the next week or so and add if necessary. |
What Clay said!
Good time for a coolant flush if ya dont know how long its been. Search for Gooch coolant flush... |
Might consider swap to ELC tooo!
(Post 10053237)
What Clay said!
Good time for a coolant flush if ya dont know how long its been. Search for Gooch coolant flush... Stewart |
