enzer2406 |
02-11-2011 03:33 PM |
High idle and sometimes sticks around 3000
I replaced the TPS on my '91 F-150 5.0L about three months ago. Since then I have been having a problem with my idle hanging around 1500 all the time. Every once in a while it will idle just under 1000 where it belongs. When it's cold it likes to stick up around 2500 - 3000 when I let up to shift. Usually when I tap the accelerator real quick it will idle back down to around 1500. When I replaced the TPS I pulled the entire throttle body off and cleaned it completely, so my butterflies are not sticking and it does not feel like my accelerator cable is sticking. I pulled off the front half of the IAC and cleaned it out really well too. I also scraped all of the silicone sealant off the throttle body and replaced it with a gasket. When I idle it up under the hood the spring is returning the trottle to original position but the idle still sticks around 3000. Is there anything I missed besides buying a new IAC?
