electric fan?
Got most of my harness finished and started the truck today. Po has electric fan on truck on engine side. Hooked up adjustable thermostat. Fan blows away from engine towards grill. Should this fan be on the grill side or can i reverse two wires going to fan motor hot and ground. First time dealing with electric fan. Tha nks Bob
Reverse the wires. You'll be fine.
Some fans are either push or pull. Usually, you flip over the fan (blades).
I look forward to switching to an electric fan ASAP.
So how do you get them to read the engine temp? The sending unit in my '56 223 is really unique and I don't understand how I will not only have a temp sending unit for my original gauge, but also fit some kind of temp switch for the fans to turn on in the same hole in the head..... |
I switched the wires and it reversed the rotation, But the colors are now reveresd of course. Fan black goes to blue switch and fan blue goes to ground. I think it shoudn't matter. I used one of these from mid fiftys, But this one seems to be cheaper. Probe goes in rad so you don't touch your regular sender.
DERALE ELECTRIC FAN ADJUSTABLE IN-CAR TEMP SWITCH KIT - eBay (item 330511166580 end time Jan-21-11 05:55:32 PST) |
Boaterbob have you had any issues since changing the polarity of your Elec. fan? I just purchased a 16" this evening and was reading over the specs and destructions before installing. Being a cheaper fan I wanted to make sure I wouldnt burn it up so figured Id hit the Forums. Any issues with yours or anyone else who have performed this same swap?
thanks Sean |
No issues at all.
no issues at all, With about a 1000 miles on truck. Bob
Thank you sir!
Could we get some pics? :D
I put a elect. fan on the outside and still have the fan on the motor. Help keeps it cool when i'm running 100 mph with the ac on high. LOL
