Shift motor transfer case harness different - 98 Navigator
All,
I'm replacing the shift motor on the transfer case and wire harnesses connectors are different than this. http://info.rockauto.com/getimage/ge...8/48207-01.jpg The connector on the Navi has 13 pins I believe, this unit has 7 and a different size. What gives? Thanks, Jack in Ohio |
Originally Posted by AllAboutTL
(Post 9504025)
All,
I'm replacing the shift motor on the transfer case and wire harnesses connectors are different than this. http://info.rockauto.com/getimage/ge...8/48207-01.jpg The connector on the Navi has 13 pins I believe, this unit has 7 and a different size. What gives? Thanks, Jack in Ohio Are you certain your motor is bad? |
I just looked at the pics on Advace's site for mine and it shows the same motor. Which trans do you have, 4R70W or 4R100? It may make a difference.
Originally Posted by Moto Mel
(Post 9505711)
Now the fun begins! I had run into the same thing on my expy. the auto 4x4 complicates things a little, the extra wires are due to the a4wd. I had a friend get me a wiring diagram and I had to pull the wires from the old plug and switch them to the new plug. The shift motors at all the local parts houses have the same listing for the one shift motor. Pay very close attention to what wire comes from where, it took me two or three tries until I got it right. Use a pick tool to pull out the red wire retainer thingy from the plug and the wires pull right out.
Originally Posted by trsimmons25
(Post 9507832)
Thank you, Jack in Ohio |
You might look at a newer model Navigator or Expedition's motor and connector.
Misson Accomplished
Well, thanks to guidance from all of you, and this video from 1AAuto on YouTube, my transfer case shift motor replacement is complete and working. The trick as trsimmons25 explained above, is popping out the wires from the old connector and inserting them into the new connector. Watch the video and you'll have confidence to proceed. YouTube - 1AAuto.com Replace Fix 4WD 4x4 Transfer Case Shift Motor Ford Explorer Mercury Mountaineer 1995-01
After removing the red collar with a pair of needle nose, use a small pointed object, such as a jewelers screw driver, and release the tab inside the connector for any given pin whilst gently pulling the wire from the rear. (you can practice on the new connector before starting) Pull out pins (old connector) and insert into the new connector in the same position until it clicks into place. I roughed-in the new motor in-place, while the old motor hung, just to make the pin transfer process easier. Once all the pins are transferred, I used blue RTV gasket material on the encoder end and bolted in permanently. Everything else is straight forward. I bought an OEM motor to avoid any hassle with wrong connector, Chinese crap etc. The OEM part (YL1Z-7G360-AA) was ~$250 (made in Korea). After market could be had for ~$100 or less on ebay from 1AAuto www.1aautomotive.com Thanks, Jack in Ohio |
