Sorry Keith, I meant to include these pictures.
https://cimg5.ibsrv.net/gimg/www.for...d96b3d14a1.jpg https://cimg8.ibsrv.net/gimg/www.for...31a21a04d5.jpg https://cimg2.ibsrv.net/gimg/www.for...8c3627a559.jpg |
Anybody have an extra bed for a 1950 F2? Mine is rusted more than not.
F-100 Flatbed/stakebed running boards
Any one have a lead on the short running boards for a 1953 to 1956 F-100
https://cimg8.ibsrv.net/gimg/www.for...7e1a37cf1f.jpg flatbed or stakebed. They are 41" long. I need to buy a pair. |
I need Y Block flywheel. My step-son picked up a complete Y Block minus the flywheel and wants to rebuild it. According to the casting on the block it's a '62-64 292. Just thought I would ask around in case anyone had one to sell.
Don't know if anyone in here might be interested. 1952 Ford F4 dumptruck. All original and with minimal rust. Coming out of PA as a barn find. Didn't have the time to do the work like I thought I would be able to.
7500$ and comes with a whole spare front end directly from Ford circa 1970s. Send any questions or offers if interested to cj@cjduggan.com https://cimg1.ibsrv.net/gimg/www.for...b9c060f72c.jpg https://cimg2.ibsrv.net/gimg/www.for...392856e368.jpg https://cimg4.ibsrv.net/gimg/www.for...7ce8107b32.jpg https://cimg5.ibsrv.net/gimg/www.for...014bc169c0.jpg |
51 F2 Parts
I have for sale front and rear 8 lug 12” drum brakes, and original Timken rear axle removed from my 51 F2 in good functioning condition. $350
https://cimg3.ibsrv.net/gimg/www.for...638cf4d90.jpeg https://cimg7.ibsrv.net/gimg/www.for...385534e31.jpeg Also, I’ve got a set of (4) 6x16 original 8 lug steel wheels in good condition. $350 And, a seat mounting bracket in excellent condition. $100 https://cimg1.ibsrv.net/gimg/www.for...fa3c5ceb5.jpeg Will sell or trade. I’m looking for a 48-52 Tool Tray, and a heavy duty rear bumper, 51-52 6 volt wiper motor, a cab sun visor, or other weird truck accessories. Located between Nashville and Louisville off I-65 near Bowling Green, Ky. Thanks- Whitley |
I have a 6 volt wiper motor and switch. I can only assume that is works, no way of testing it unless someone can tell me how. Not sure how to get it to you affordably though, but open to your thoughts.
48-50 gauge cluster $60 plus shipping
F2, F3 express bed no tailgate $1000 with fenders, $500 without 48-52 panel rear bumper $200 also have a set of 4 17.5 8 lug wheels for sale. https://cimg9.ibsrv.net/gimg/www.for...8f03c27be4.jpg https://cimg0.ibsrv.net/gimg/www.for...9252000768.jpg https://cimg2.ibsrv.net/gimg/www.for...9822b7543e.jpg https://cimg3.ibsrv.net/gimg/www.for...13901839a3.jpg All parts are located in South East South Dakota, will ship |
5200 1956 Big Back window. There is a back cab panel with BBW that would fit 53-56 in the aftermarket, glass and rubber too.
Originally Posted by O'Mahony
(Post 19353944)
Live near Santa Barbara, Calif and on the hunt for a short tail shaft 3 speed trans. My truck is a 1954 F100 and I want to replace a OD trans to put my truck back to stock. Prospect tranny's need to be within a couple of hours drive time for me. Thanks for any help. tim
Looking for inline/straight 6 air deflector panel for 48-52 f1.
Ford cast iron bellhousing.
It has been bead blasted, inside has electrical insulating varnish, outside rattlecan flat black primer. $50 each + shipping. |
Just starting to clear out my garage and have for sale numerous spare and excess parts for my 3 speed, 223, 56 F-100 that I've accumulated over 35 or so years. PM me if you're interested.
56 223 block with crank shaft, flywheel, pistons, oil pan etc still installed. It was still running when removed 4-5 years ago 56 223 head 56 223 rocker arms, shaft, supports. Used, not rebuilt; is as was removed 223 truck exhaust manifold. Heat riser valve assembly included, but does not move freely/at all 223 truck exhaust manifold. No heat riser valve 223 intake manifold 2 used steering gear boxes with shafts Stock steering column components 56 223 3-speed bell housing rear bumper mounting brackets. NOS....purchased but never used as I chose to retain "farm bumper" 2 or 3 3-speed transmissions; torn down, cleaned up, damaged/worn gears and bearings replaced, reassembled, ready for use. 3-speed overdrive unit transmission housing case 3-speed overdrive main case (7006); empty, no other parts inside Original drive shaft for 3-speed light duty non-overdrive transmission Several one barrel Holley carbs and associated parts, a couple with glass bowls. Torn down, cleaned up, re-assembled with rebuild kit parts. Cab heater unit housing parts Local pick up or buyer arranged shipping for large or heavy items. I'm located in Northern Virginia. https://cimg5.ibsrv.net/gimg/www.for...89d4405a22.jpg https://cimg6.ibsrv.net/gimg/www.for...3cc3e23e29.jpg https://cimg7.ibsrv.net/gimg/www.for...5c5c46105e.jpg https://cimg8.ibsrv.net/gimg/www.for...b2792d0dde.jpg https://cimg9.ibsrv.net/gimg/www.for...8fd20f1369.jpg https://cimg0.ibsrv.net/gimg/www.for...4121c485f1.jpg https://cimg1.ibsrv.net/gimg/www.for...74ea56eed2.jpg https://cimg2.ibsrv.net/gimg/www.for...57c9bd2cd1.jpg https://cimg3.ibsrv.net/gimg/www.for...9e8316d8ef.jpg https://cimg4.ibsrv.net/gimg/www.for...8ef9006060.jpg https://cimg5.ibsrv.net/gimg/www.for...cb5d61189b.jpg https://cimg6.ibsrv.net/gimg/www.for...fccd7da6b9.jpg https://cimg7.ibsrv.net/gimg/www.for...bc33db67ee.jpg https://cimg9.ibsrv.net/gimg/www.for...a53f30cd9d.jpg https://cimg0.ibsrv.net/gimg/www.for...07a1c4de68.jpg https://cimg2.ibsrv.net/gimg/www.for...4c6920ec33.jpg https://cimg3.ibsrv.net/gimg/www.for...9857222842.jpg https://cimg4.ibsrv.net/gimg/www.for...7db7b4c410.jpg https://cimg5.ibsrv.net/gimg/www.for...545ff3beb6.jpg https://cimg7.ibsrv.net/gimg/www.for...aef9e7d694.jpg https://cimg8.ibsrv.net/gimg/www.for...c77dabac60.jpg https://cimg9.ibsrv.net/gimg/www.for...fe8b445fa0.jpg https://cimg0.ibsrv.net/gimg/www.for...6137a4d8e2.jpg |
'48 F-3 O.E. parts available
I have numerous original equipment (at least to me) parts from a 1948 F-3 rebuild project. Below is a partial listing. Please private message if interested and I can provide pictures and additional detail. I am located in the Boise Idaho area.
battery tray rear helper springs Timken rear end Front & rear brake drums front bumper gas tank spare tire carrier 8-bolt wheels steering wheel, shaft, gear box 2 pc drive shaft Cheers, Larry |
