Thanks @FuzzFace2 and @Benztechnc , for your comments. I will check the fluid levels and report back. Also thought about getting a magnet and sticking a camera under the truck while driving might help to narrow the search down a bit.....
Also i was about to order the rubber parts for the doors, they rattle so much while driving and its beyond anoying..... Thought about trying dennis carpenter for those parts. @Ug666 sounds like you made some good progress! Do you have a garage to work in? Picture looks good, did you give her a name yet? :-X21 |
I've got the borrow of my neighbours garage for short periods of time, not ideal but it does give me a hard floor rather than dirt for the cherry picker to roll on.
As to a name, I've called it every name under the sun at various points... It's going to be the better-halfs so she'll likely name it once it's in use. If past experience is anything to go by it'll be known as the F100 or red (or whatever colour we decide on later) truck. I'll probably continue to invent appropriate names on the spur of the moment as circumstances dictate... I've got to get new window runners and beltline rubbers for mine so I'll be interested to know where yours come from and any problems you have. |
Originally Posted by superspost
(Post 18462779)
I was actually thinking about that... go there friday after dinner and look at some parts :-whud
@Ug666 i will def let you know what the parts look like.... i found this post helpful... there seem to be some premium suppliers that are pretty expensive... not sure i want to spend $800 only on the window rubbers just yet... https://www.ford-trucks.com/forums/1...strip-kit.html |
There’s also a small salvage yard right up the rd in kannapolis that had a few of those 70s fords out in it. It’s an older fellow that has the yard at his house. Next time I’m up that way I’ll see what he has. I know most of his vehicles are not wrecks just vehicles he has bought to part out... |
I bet y'all thought this thread is dead but with the warmer weather and the help of Josh, I got some progress on the "holy" truck and wanted to share...
Let me share what has happened: Noise Issue
Other progress
I will post some pictures in a little bit.... hopefully i can share more updates soon and get a definitive solution for the grinding noise. |
(Post 18588465)
Other progress
i was thinking R&P too.. mine howled right before it went.. Pinion bearing went and then the gears beat the crap outta each other...
If it was that low its possible you've hurt the pinion bears. They typically make the most noise under load from my experience.
Oh, as for the speaker, I'd check out Crutchfield. They should be able to provide the spec and size of the door speaker and get all your information there. I'd go ahead and pick up another qt. put that in. Then check the front, if the rear was neglected, the front probably was as well.
Carburetor rebuilt started
Last weekend I started on the carb rebuild project and everything looked pretty good until i hit the second jet - it just does not want to come out. I've been letting it soak in WD40 for over 24h but it is still stuck....
https://cimg7.ibsrv.net/gimg/www.for...d0af4b984a.jpg https://cimg2.ibsrv.net/gimg/www.for...e8e91d8b68.jpg https://cimg3.ibsrv.net/gimg/www.for...2e103d059b.jpg https://cimg4.ibsrv.net/gimg/www.for...c760d91d98.jpg https://cimg7.ibsrv.net/gimg/www.for...8e0a577c0e.jpg https://cimg1.ibsrv.net/gimg/www.for...4ce868e613.jpg one of the jets does not want to come out |
@supersport How is the Carb rebuild coming?
i broke the easyout inside the jet 2 nights ago... brought it into work to see whether it could be drilled out on a kneemill.... ... sooooo not very good :-banghead:-X24
yeah. that doesn't sound too good. Let me know what, if anything I can do to help. but easy out's and milling machines sounds pretty bad for a carb rebuild.
found myself a "new" old license plate, that I can apparently use! :)
https://cimg7.ibsrv.net/gimg/www.for...cc774744b9.jpg https://cimg5.ibsrv.net/gimg/www.for...eb536bd7b8.jpg |
