Ford Truck Enthusiasts Forums
-   6.0L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum107/)
-   -   NO GODFORSAKEN BOOST (https://www.ford-trucks.com/forums/990323-no-godforsaken-boost.html)
hifiman 09-10-2010 03:41 PM
Originally Posted by lakewood (Post 9314302)
Just pulled the EBP out, i started the truck and put my finger over the top of the EBP tube, exhaust flowed out seemlessly, so the tube isnt clogged. My mom was by the local dealer so shes picking up the part for me. Hopefully truck will be up and running tonight, ill post when the good news comes.
Thanks for all the help
Make sure that when she picks it up that it is the right one. When I went to Ford for mine and told them it was for a 05 they gave me one that didn't fit because my engine build date is 09/04. The one for my truck had a thinner stem and smaller threads and the one they handed me was a bigger(wider) stem with bigger threads. Lucky I took the old one with me and saw the difference.
hifiman 09-10-2010 03:44 PM
Good luck and I will keep my fingers crossed it will work for you as mine did. If it doesn't, check the contacts and make sure they are clean as the plugs have been known to fail also. If it doesn't at least you will know its something else and at least you will have a new upgraded EBP sensor on your truck.
lakewood 09-10-2010 04:16 PM
thanks, i rememebered that, i checked mine its the 1/8th. i sent her a text with all the specifics so she knows what to get
lakewood 09-10-2010 04:17 PM
But once again to everyone that helped thanks, gotta go fix a broken u-joint on the bush hog:-X09
