Originally Posted by Coalroller
(Post 9109601)
also just a reminder even tho the axle tubes are thick, try not to lay full beads and get the tube too hot because even the smallest warp will over time, ruin the axle
yes a semi can carry 20,000 lbs on rears but have you ever noticed that they don't squat much as a pickup does with only 5-8k. if you do it protect the bags and lines from rubbing on anything and expect to replace bags about every 3-5 years as they seem to develop leaks at about that much use.
Originally Posted by Otahyoni
(Post 9108941)
Yep, I planned on making little triangle gussets. We have leveling valves laying around at work. I didn't think about the sway bar... I'll have to find something...
Another little trick i was going to add was a dump valve to make loading the bed easier. |
Originally Posted by poocher pup
(Post 9109937)
Originally Posted by Ford_Six
(Post 9110356)
Use a Haldex PR series valve, they have a built in dump port that's much faster than waiting for the whole suspension to vent through a dash switch. With that valve, you just put pressure to the dump signal port, and it'll vent the whole deal in seconds.
