Originally Posted by leadmic
(Post 20137193)
Well we will have to agree to disagree. A side note I have had both have you? Also I tow heavy often, although it is mostly dry conditions with low traction at tmes.
Have ever had a selectable locker? Have you ever had a detroit lock up in a low traction situation while towing? I have and its not fun. If their is any crown in the road you are going right to the sholder.
(Post 20137247)
Please reread your last post. It doesn't make sense. A Detroit is always locked and can be hard to unlock unless you are going around a corner in a high traction situation. A true-trac is normally unlocked and will lock under throttle in a low traction situation. Towing with a Detroit is ill advised and can be down right dangerous in low traction situation as they can make it very hard to control your vehicle on a roadway. A true - trac locker is a better choice for towing. A selectable locker is good because you have full control of it. When you need it you lock it and when you don't you unlock it.
(Post 20137326)
Well at least we agree on the truetrac. Its well known about the Detroit locker and towing. Call Eaton and see what they recommended. Their website says that the Detroit is primarily for drag racing. So again we will have to agree to disagree. In the end most automotive manufacturers have gone to selectable lockers because they work better and create less problems.
I have seen far more problems with selectable lockers than Detroit lockers. This comes straight from Eaton's website.
"The Eaton Detroit Locker can enhance traction in a variety of vehicles. Units are currently available for front- and rear-axle applications, including c-clip style axles. Below is a list of common uses:
From the Eaton Detroit locker website facts page:
Can I run a Detroit Locker on the street?While many people do use the Detroit Locker during everyday street use, the Detroit Locker is a very aggressive traction aiding differential, initially developed for off-highway, heavy-duty applications. Eaton also makes many applications for on-highway, heavy-duty trucks.In the 1960’s, the Detroit Locker became a factory option in some Detroit based OEM muscle cars. While most drivers of street cars will find the aggressive engagement of the Detroit Locker objectionable, drag racers enjoy the auto-locking functionality the differential delivers. The Detroit Locker allows drag racing vehicles to differentiate when turning corners, while offering strength comparable to a full spool. |
No where does it say it's mainly for drag racing. It's a great choice for a truck that you want simple and reliable mechanical locker that requires no cables, wires, or air lines to work.
And nowhere in yoir post does it say towing. It does a very aggressive locker.
(Post 20137882)
