Originally Posted by Bonanza35
(Post 19356118)
I'm following this, going to be another expensive upgrade for our trucks!
I'm going to be interested in seeing you layup the carbon fiber.
Originally Posted by Dan V
(Post 19357298)
https://cimg8.ibsrv.net/gimg/www.for...ee264b033d.jpg https://cimg3.ibsrv.net/gimg/www.for...15bd6029f3.jpg |
Ahh, a fellow cyclist....
Mad skills/ patience to R&D your seat :-X22 I spent more than I'd like to admit just adjusting mine up/down/front/back/tilt to fit me just perfect on all the hills and flats after many rides :9 |
You cycling people....This is a saddle, not that carbon fiber thing attached to a post.
https://cimg0.ibsrv.net/gimg/www.for...714afe1e96.jpg |
:-offtopic
I used to ride sport bike motorcycles... Does that count? 2003 GSX-R 600cc Alstare and a 2008 Hayabusa 1340cc. https://cimg4.ibsrv.net/gimg/www.for...9b776c06f5.jpg https://cimg8.ibsrv.net/gimg/www.for...dc57960c98.jpg ------------------------------------------------- On a thread related note, what would you change in the shape or routing of the Y-pipe if you did make your own out of carbon fiber? Would you put a dent or diversion in the upper part of the Y that goes to the IC tube? Have you thought that far yet or just set a COA in case you need to go that far? |
nope......
Im with Dan on the saddle issue.
Noob,If theres going to be trouble with y-pipe,just fab completely new with different angle..? |
Originally Posted by Wes444
(Post 19357934)
(Post 19357972)
https://cimg0.ibsrv.net/gimg/www.for...714afe1e96.jpg https://cimg0.ibsrv.net/gimg/www.for...0191f4dde7.png
Originally Posted by Sous
(Post 19357986)
2008 Hayabusa 1340cc. https://cimg8.ibsrv.net/gimg/www.for...dc57960c98.jpg ------------------------------------------------- https://cimg6.ibsrv.net/gimg/www.for...0ed8979229.jpg
(Post 19357986)
Originally Posted by FinnishStroker
(Post 19358109)
Noob,If theres going to be trouble with y-pipe,just fab completely new with different angle..? https://cimg2.ibsrv.net/gimg/www.for...c3e0fdf4de.jpg So to answer your questions about the y-pipe directly, I am planning on a minor reshaping of the upper portion that connects to the CAC pipe. A simple dent is easiest but not the best thing for flow. I'm thinking the part that has to clear the actuator will be a flattened oval being careful to maintain the same cross-sectional area as the round part, and then extending it so it sticks out over the passenger VC a little more to give room for the boot and clamp to clear the actuator also. That means I will have to trim the CAC tube and silver solder on a new anti hose pop off bead. Geez that's a lot of work now that I have typed this all out. Anybody want to buy a VGT/VNT housing? |
Time for a 1 or 2” body lift?:-down
reduce your suspension lift to compensate? |
I know you are not in the same ballpark regarding injectors or turbo, but most of us did not use the CSD Y-pipe mounting bracket.
If you could leave the bracket off, would that give you enough clearance for the VGT? @countrycar , did you use the bracket? I ask because your build is closer to FTN's build than most of the others on here. |
(Post 19359025)
(Post 19359034)
It's the pipe itself that is contacting the actuator as it sits currently.
Interesting and highly anticipated build you have going on. |
Noob you may want to look into getting a bead roller as opposed to silver solder, or have a shop slap a bead on your CAC pipe.
