Nice pics! The good news is you have an existing evap canister so you might be able to return the one you bought (those are EXPENSIVE!). I couldn't see the vacuum distribution node but it might be hidden by the air cleaner. When you're feeling better, could you get some pics around the carb with the air cleaner removed?
I also saw the existing vacuum reservoir looked a little rusted and had been tossed to the side (passenger side close to the blower motor). Probly why they disconnected the other stuff... rust corroded and prevented vacuum buildup. https://cimg1.ibsrv.net/gimg/www.for...b3ac46ce4b.jpg |
https://cimg6.ibsrv.net/gimg/www.for...c6cdb992bb.jpg
https://cimg7.ibsrv.net/gimg/www.for...2fdba948bb.jpg https://cimg8.ibsrv.net/gimg/www.for...0b13f3bc92.jpg https://cimg9.ibsrv.net/gimg/www.for...dd0e8bb465.jpg https://cimg0.ibsrv.net/gimg/www.for...73d18881d3.jpg https://cimg2.ibsrv.net/gimg/www.for...a544ad49cc.jpg https://cimg9.ibsrv.net/gimg/www.for...44b6c9eb6c.jpg https://cimg1.ibsrv.net/gimg/www.for...1d8ea382c5.jpg https://cimg2.ibsrv.net/gimg/www.for...4c852475c0.jpg https://cimg6.ibsrv.net/gimg/www.for...354fdfd84b.jpg https://cimg8.ibsrv.net/gimg/www.for...1ea29a2e05.jpg |
Sorry I have took so long to post these pictures my health has been struggling I went to replace the oil sending unit and the temperature sending unit wonder about wore me out I've been trying to track down a rattling in the engine how to replace or push rods that were bent I had thought that the rattling was another turned out to be the power steering pump Pick-n-Pull provided a new power steering pump then the struggle with pulley exchange started realized I didn't have the tool the emergency brake lines have been cut an old Parts truck provided those with help from a friend so at this particular time I am back focusing on smog
this vehicle had no Eve at canister or vacuum can I acquired these from a Parts truck of the same year and engine that is why they are not hooked up that is my problem I don't know how to put an end to what I purchased a ton of vacuum lines
Did you know your PCV valve is not in its proper place? The choke housing is missing. [trying to be helpful!] :)
there is a line coming out of the back bottom of the carburetor has a screw inserted into it. there is also a big line coming from the front of the carburetor that leads to nothing, I assume this was the line that went to the fuel canister for vapor. I am not sure that is correct my only question would be what sort of valve would connect it or some kind of fitting tee, check valve?
Originally Posted by Tooleytool
(Post 16338379)
(Post 16338388)
(Post 16338410)
there is a line coming out of the back bottom of the carburetor has a screw inserted into it there is also a big girl I'm coming from the front of the carburetor that leads to nothing I assume this was the why not went to the fuel canister for vapor not sure that is correct my only question would be what sort of dog with connect it or some kind of fitting tee check valve?
(Post 16338410)
If you don't have a picture of your vacuum diagram on the top of the grill, you can view similar ones on these threads too: https://www.ford-trucks.com/forums/1...to-thread.html https://www.ford-trucks.com/forums/9...questions.html https://www.ford-trucks.com/forums/7...-acronyms.html Here's my comments about the pictures: https://cimg8.ibsrv.net/gimg/www.for...60c411ef1b.jpg Carb choke housing missing https://cimg9.ibsrv.net/gimg/www.for...6870c5867b.jpg This thing goes in this hole https://cimg0.ibsrv.net/gimg/www.for...651cfd277f.jpg vacuum distribution from intake manifold https://cimg9.ibsrv.net/gimg/www.for...986d4439e0.jpg Valve cover breather. Likely connects to air cleaner |
(Post 16338482)
I'm sorry your health is struggling. But, I'm not going to be much help as I cannot get my head around your posts. Without capitalization nor punctuation it takes too much of my time to work out what you are saying. And, as a volunteer my time is limited. So, I tend to try to help when I can easily understand what is being said. Good luck, and I hope your health gets better, quickly.
You are doing a good job. :-X22
I apologize gentlemen I am using a mobile device while driving to Sacramento over a doctors appointment using the microphone to text but I see the issue .sorry for waste of time .thank you for the help I received I am starting to get an idea of the system requirements. I did purchase a thermostatic choke and installed it sorry I had not updated the photos since that I do appreciate everyone taking their time saving me some money and also just to get my dad's truck rolling is awesome
(Post 16338678)
(Post 16346310)
Well I did all I could do and sent the truck in for smog diagnosis. My fingers are crossed.
Originally Posted by Braggs
(Post 16346459)
Smog diagnosis? Don't they exempt the vehicle after a certain age?
