^^^This^^^
I assume the infatuation comes from diesel drag trucks that do smoke a lot. Just remember that drag trucks have drastically lowered compression and huge turbos and are made to perform at high rpm WOT conditions only. They are basically worthless on the street under mixed driving conditions. If you try to make that kind of smoke from your truck with stock compression and a small turbo you will melt the pistons. You are fuel limited, so smoke is just wasted potential power. The heavy smoke does not mean that your monster turbo has yet to fully spool and fill decompressed cylinders as you reach WOT, it means your turbo is way too small and/or your truck is grossly out of tune. Like I said, you will melt pistons, blow head gaskets and look like a fool doing it. |
Originally Posted by Ford F834
(Post 16236879)
Excessive smoke and noise are the kinds of nonsense that give diesel owners a bad name, and these behaviors bring about legislation that none of us want... hence the snarky sarcasm. To be a little more constructive, stop trying to impress your buddies with visible and audible symbols of power, and instead work at blowing their minds with actual horsepower and torque. Start with ditching the garbage ATS air cleaner box and filter, and build yourself a good cold air intake. Learn how to time the injection pump correctly and how to adjust the fuel for the amount of air your turbo can push. Tuning on these things is huge. Once you get a taste for the potential gains you will forget all about wanting to make noise and smoke. It's just not that hard to get these things to ~200 hp at the wheels and out run a stock early Powerstroke. Make your buddies eat your dust instead of choking on your own smoke.
How would I go about getting rid of the ATS air box? I'm still super new to this so I'm just trying to go step by step. And what would you recommend putting on there once I do end up getting it off |
i can't say about the air box .. but you can do injectors and valve cover gaskets pretty easy .. about the most difficultly you'll have is the rear most bolt passenger side on the valve cover .. not tough to do ..
do use the rubber kindof valve cover gaskets not the cork or paper kind .. so you can take them off in the future and reuse them .. to get the injectors off just take off the pinch anti vibration clamps the hold the lines together in sets of 4 and 2 .. then they will be loose enough to get off the injectors .. don't take them loose at the pump .. remove and replace the copper washer under the injector .. replace them with only with injectors from a reputable re builder not el cheepo injectors .. also do replace the return fuel lines and o-rings while doin' em .. i believe macrobb - suggests using lithium wheel bearing grease that seems like the best advice on sealing up o-rings .. just grease em' up and seat them well .. replace the fuel filter while your at it as it will have to be removed to get to the valve cover gaskets anyway .. do make sure you tighten the fuel lines well .. not strip them but make sure of no leaks .. welcome to the forum .. we all getta kick outa ripping on folks who are all about the smoke but that aside we're happy to help and good luck with the new truck :-X22 |
There are three different models of ATS turbo kits for the IDI. All three use an aluminum box with a flat filter in it. Unbolt it from the intake manifold, and what is left is the rubber boot connecting the box to the inlet side of the turbo compressor housing. You can buy or make a rigid tube routed to someplace in your engine bay where you can mount a high flowing quality air filter. Here are a couple examples:
https://www.google.com/imgres?imgurl...act=mrc&uact=8 https://www.google.com/imgres?imgurl...act=mrc&uact=8 Here is a ATS 093 turbo with the air box off to show the turbo inlet: https://www.google.com/imgres?imgurl...act=mrc&uact=8 R&D sells one specifically for the 093 kit: Factory Turbo/ 093 Air Intake Kit I suspect you may have one of the older two kits and may have to make your own. But these should give you an idea of what needs to happen. You need to get rid of the restrictive box filter and have good air flow in and out of your turbo. If it says ATS on it, it has a 3" exhaust down pipe which is plenty on the exhaust side as long as the rest of your exhaust is 3" or better and free flowing (straight pipe, glass pack or high flow muffler). |
Problems with pictures... let's try as direct attachments hosted on FTE:
https://cimg0.ibsrv.net/gimg/www.for...6b7d3ced6.jpeg https://cimg1.ibsrv.net/gimg/www.for...a91208ae5.jpeg https://cimg2.ibsrv.net/gimg/www.for...26362d4f0.jpeg |
I'm running 9.5*" is this a better way to time . justin said 5.5 or 6
Originally Posted by 94iditpuller
(Post 16243817)
(Post 16243817)
I can floor it at 45 mph and lug the engine with bull moose and misters pull all the way to 75mph with only 7.5 psi form turbo and egts will only hit 1150 |
