Originally Posted by Captn B
(Post 14658362)
I am getting a slight bit of pulsation, but only if I am at highway speeds and tap the brakes very lightly. Otherwise, I don't feel any. I had it at a shop for inspection and they wouldn't let it pass with the current rotors.
I feel they were looking for an excuse to not do the work as they don't normally work on this big if a vehicle. I won't be going back to them. I believe the rotors are good for quite a bit longer and had them on the to do list, but figured I might as well just knock them out now. Interesting, so stay away from drilled rotors huh? That's the first I have heard that mentioned. Welcome to FTE - the excursion forum is fabulous.. LOTS of info you might not know on here.. https://www.ford-trucks.com/forums/1...llllppppp.html https://www.ford-trucks.com/forums/1...k-hp-pads.html Use the search then select advanced.. enter. "drilled rotor" IN quotes.. then un-select all the forums and just select excursion... grab a drink and spend a few days reading... Hundreds more threads... (2nd post in each contains drilled rotor message) |
Originally Posted by Misky6.0
(Post 14658506)
I drive an F250 Super Duty, but the info is valid for Excursion- when I did my brakes, I ordered AC Delco "police duty" rotors from Amazon. I think they call them "performance duty" or something similar now. They are drilled and slotted. With them, I used Motorcraft Extreme Duty pads.
That said, I work this truck hard. It isn't uncommon for the bed to be piled cab-high with firewood while towing a car trailer with 3-foot sides piled with firewood. I've also towed heavy equipment on a heavier trailer. What I'm getting at is this- I don't buy into the bias on the Internet about the problems with running drilled rotors. My setup has worked well without any brake fade or heat issues. When the day comes that I have to do a rotor/pad change on another SD or Ex, I will be going with this same setup again. It does the job and does it well- without the added expense of all the fancy stuff I've read on these forums. For what some people here have spent on one fancy rotor, I was able to do both rotors and pads, and the performance and wear have been excellent. |
(Post 14657923)
Wow! I was just quoted $560.20 for 4 new motorcraft rotors from the local Ford dealer
Amazon.com: Power Stop K1906 Front/Rear Ceramic Brake Pad and Cross Drilled/Slotted Combo Rotor One-Click Brake Kit: Automotive
Might hafta do this myself! Curt |
A few months ago I went with a set of these Callahan slotted/drilled rotors and pads for about $120 for the whole front end.
http://www.ebay.com/itm/FRONT-Performance-Callahan-Drilled-Slotted-SPORT-Brake-Rotors-Ceramic-Pads-4WD-/300660465395?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2000%7CMake%3AFord%7CModel%3AExcursion&hash=item4600c29ef3&vxp=mtr They had good reviews and I figured it was worth a try after comparing the price to Stop Tech. So far, several thousand miles later of hauling down 37" tires on and off-road and I am VERY happy with them. They have great stopping power and I have never felt any fade, even when coming down long mountain passes at a decent grade. Plenty of dips into water and mud with no ill effects. I had read a ton of people complain about cross drilled rotors and there seems to be a lot of negative words from people who have never run them. I've been very happy so far but I guess I'll be able to report better in another 20k miles. Out back I have standard Napa grade pads and rotors. No comments either way on those. They work. I've also been running cheap eBay Chinese COPs (ALL 10!) since I bought the truck a year ago, so take my opinion with a grain of salt. People on here skewer you for even thinking about running non Motorcraft parts. :) |
hey them are only 5 lug!
Originally Posted by Skip1970
(Post 14673524)
