Andersen WDH in Colorado
For Sale
Miscellaneous
  • Miscellaneous - Andersen WDH in Colorado - Used - 0  All Models - Highlands Ranch, CO 80130, United States
    Expired
  • Price
    $400
  • Location Highlands Ranch, CO, 80130, USA
  • Condition Used
Description:
Andersen 3394-3 No-Sway 16K Weight Distribution Hitch 3" Shank 2-5/16" Ball 4" Drop.
I'm selling this system because I bought a Northwoods Desert Fox 27FS (12,800 GVWR) that has a higher tongue weight than the Andersen specifications. The Andersen WDH worked great for my prior trailer (11,500 GVWR). It controlled sway quite well, even in Wyoming. It won't give you a hernia moving the shank and ball mount around and doesn't require an 800 lbs Gorilla to set the tension.
The price for just the 3394-3 kit brand new is $789.
Spare parts included:
Red urethane spring, part number 3358 ($45)
Shackle, part number 3374 ($6)
Locking Pin for Anti-Sway Plate, part number 3430 ($5)
Also included is Andersen part number 3351.3, which is a 3" shank with 8" drop. This part is brand new, still in the box (taken out of the box for the picture), never installed. This shank does not have a ball mount on it.
The socket wrench, shown in the picture is not included, but the socket is. One of the 2 5/16" ***** is rated for 14,000 lbs, the other 2 5/16" ball (not shown) is rated for 16,000 lbs and is mounted in a separate shank and ball mount. I had multiple shank/ball mount setups because the tongue height of the toy hauler changed when it did and did not have the side-by-side in the trailer. You're getting three shanks and two ball mounts. The ball mounts are interchangeable with all three shanks.
Note that the included shanks fit a 3" receiver and will not fit a 2.5" or 2" receiver. Andersen sells shanks that fit those receiver sizes.
Local sale only. Sorry, this stuff weighs too much to ship. My zip code is 80130.
From the Andersen Hitches website:
We didn’t just raise the bar, but we eliminated the need for sway bars entirely. The design of the Andersen Weight Distribution Hitch eliminates the sway and bounce in your trailer, using our interconnected motion-dampening chains and sway-control ball housing system.
Weight Distribution Hitch Features:
Rated up to 16,000 lbs GTWR & 1,600 lbs Tongue Weight
Grease-free system ball turns with trailer
Easy installation – no leverage bars needed
Sway-control automatically adjusts to load
Patented shock absorbers prevent bouncing like traditional weight distribution hitches
Weighs less than 60 lbs
