92 Ambulance, 7.3 IDI NA
For Sale
1992 Ford E-350 Econoline Club Wagon
  • Expired
  • Price
    $4,000
  • Location Harrison, TN, 37341, USA
  • Condition Used
  • VIN 1FDKE30M6NHB48981
  • Mileage 153,500
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Van
  • Exterior Color White
Description:
New master cylinder, new front rotors, calipers and pads. Vacuum pump replaced, return lines redone and electric Facet fuel pump with remote mounted filter in addition to original filter.  Rear brakes redone except for passenger side cylinder that would not let go of the brake line. Have the cylinder and flex line to frame. Brakes feel a little soft.  Batteries new in 23 and 24. AC works fine and in the back also. Ditto for the heater.
This motor is worth more then the van. It is clean and runs great for it age. Full syn, fumato valve and 3000/3500 mile changes. Has Battery Tender installed and has plug in at back to always charge the batteries when sitting. Yes its necessary unless you shut of the battery disconnect.
No picture as everyone knows what a white and red ambulance looks like. Ask if you want some.
