1981 Mexican Spec Ford Bronco 4X2 - 51111D
For Sale
1981 Ford B-150
  • 1981 Ford B-150 - 1981 Mexican Spec Ford Bronco 4X2 - 51111D - Used - VIN AF2******* - 8 cyl - 2WD - Manual - SUV - Gold - Los Mochis, Mexico
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $8,500
  • Location Los Mochis, Mexico
  • Condition Used
  • VIN AF2*******
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type SUV
  • Exterior Color Gold
Description:
Hello Friends
Would you like to have a Unicorn?
This is a 1981 Mexican Spec Ford Bronco 4X2.
It is said Ford US never made a Full sized Bronco that was two wheel drive.  Technically this is one.
The truck is registered as a B200 Carry all in Mexico with the Bronco option.
The Bronco option gave you the removable roof.
If you look at the tail gate it is different from the US model.
Under the hood is a Mexican 302 that has recently had some work done.
It has had new oil and water pumps, gaskets, pulleys, a double roller timing chain and all new fluids, of course.
Electronic ignition was added, this truck came originally with points, as well as 10.5 spark plug cables and Iridium Spark Plugs
New suspension rubber has been installed as have new front shocks.
All four all terrain 31/10.5/r15 tires have also been installed.
The current owner just came back from a 6 hour trip with the trip with no problems at all.
The interior features grey cloth buckets in front with a grey cloth bench in the rear.
You might want to replace the interior with a nicer set of seats to match how nice the exterior is.
The best part of this truck is that is has no rust.  Where it lives rust is not an issue.
Quite a bit of money has been spent on this truck and only the easy part is left to do, the interior.
Can you buy any Bullnose Bronco in good shape for this kind of money?
The vehicle delivered to the Nogales border will be $8,500 dollars.
This includes professional transport from southern Mexico to my location then I will trailer it the rest of the way.
If you have any questions about the importation process, I will be happy to answer them.
You can see more Mexican vehicles at mexicanspec.com and if interested please read the Procedure link on my website to learn more.
