ZF6 transmission with manual transfer case and PTO
For SaleDrivetrain
Description:
ZF6 6 speed manual transmission and NP271 manual transfer case out of a 1999 Ford F350 7.3 PS.
This transmission has a Muncie TGS6 series PTO unit on it; the truck was a well rig.
- Transmission shifted smooth before I removed it.
- I did not try the PTO, I do not know how it functions.
- I also have the RPM control module that was in the truck.
NOTE- The input shaft is worn from common pilot bushing failure, and the mounts on the tail housing are cracked.
$2500 for transmission, transfer case, and PTO.
Might trade for cattle, John Deere equip, or a set of new injectors :-) you never know...
I have most of the components for a swap, including PCM, steering column, clutch and brake pedals, floor hump, etc. if you are interested.
