Holley Sniper 1100 EFI unit
For SaleEngine - Intake/Fuel
Description:
Near new condition. Bought in December 2021. Has run on my 300 Inline for about 4500 miles.
Reason for selling....switched to Holley Terminator EFI just because I wanted to. Sniper ran good.
Includes custom fabbed Ford truck specific throttle linkage (to use with a cable and factory pedal). Phenolic insulating spacer, and aluminum heat shield. This was done to prevent exhaust heat from the throttle body. A cooler throttle body is a happier throttle body! Also includes stainless steel fuel lines pictured. They extend to the back of the motor. -6AN fittings on those. Include air cleaner base for oval filter. You can buy the top and filter element for high performance VW shops. Also includes the unused clamp on O2 sensor bung and gasket.
What it needs to function on your vehicle is a fuel pump capable of putting out 60psi. You can use a return line or you can dead head it at the return port on the throttle body.
Instruction booklet also included.
Cash only, shipping included in the lower 48.
I will take a postal money order or personal check, as long as you are willing to wait until it clears my bank
Call or text 559-three-one-three, 6432
