Ford F100 Electric Cooling Radiator Fan Kit w/ Aluminum Shroud & Dual Speed Fan
For Sale
Miscellaneous
  • Miscellaneous - Ford F100 Electric Cooling Radiator Fan Kit w/ Aluminum Shroud & Dual Speed Fan - New - 1967 to 1973 Ford F-100 Ranger - Fort Lauderdale, FL 33322, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $100
  • Location Fort Lauderdale, FL, 33322, USA
  • Condition New
  • Compatibility
Make Model Year
Ford F-100 Ranger 1967 - 1973
Description:
Spent a lot of time and money sourcing the correct parts for my conversion to an electric fan on my 1969 F100, but in the end ended up staying with the stock fan as it may be going up north to my son soon.  This has not been installed and is essentially new components.
Fan is a newLincoln/Ford dual speed replacement fan by Dorman, not a used junkyard fan - 18" in diameter and on high speed, reportedly puts out over 3000CFM.  I wanted to have a dual speed setup, to I sourced a good Volvo Fan Relay, and a BMW dual temperature switch.  The whole thing is energized by a 200A 12V relay which is included. I attached all the wiring necessary to install and then that's where I left it.  All you need to do is decide where to install everything and recheck the wiring.  There are a dozen ways to wire this in, but I will include the diagram that I was going from.  The shroud was sized for my radiator, which I believe is a typical Ford F100 radiator size, but yours may differ.  The shroud mounts have not been drilled as yet.  There may be some additional fabbing needed on your part to install into your vehicle.  The shroud dimensions are:  29" wide (27.5" center of side flange to center of side flange) x 18.75" high, and with the fan installed, is 6.25" deep.  Please check that this fits, because there are no returns on this.  Priced to get it out from under my bed...literally cost me $300+ to put together. ITEM IS LARGE - shipping costs will vary but figure on anywhere from $50-$100.   I'm in Fort Lauderdale but travel to Tampa every week.  Pick up is free in either of those locations.
