1979 Ford F150
For Sale
1979 Ford F-150
  • 1979 Ford F-150 - 1979 Ford F150 - Used - VIN F15HRDE9628 - 8 cyl - 2WD - Automatic - Annapolis, MD 21403, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $6,000
    • OBO
  • Location Annapolis, MD, 21403, USA
  • Condition Used
  • VIN F15HRDE9628
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
Description:
1979 Ford F150 Ranger 2wd. My second dentside, I purchased the truck in Idaho to avoid rust issues, so other than surface corrosion seen in photos, no structural rust whatsoever - solid floor pans, bed, cab corners, door corners, and body mounts. 5.8M engine, C6 transmission, 9” rear end. I’ve made a few upgrades - Holley Street Avenger 2bbl with electric fuel pump and fuel regulator, new fuel tank and all lines, plugs, plug wires, new starter solenoid and voltage regulator, as well as H4 bulb/lens conversion. Truck comes with original build sheet, and manuals!
It’ll come with new KYB shocks, and a new aluminum radiator I never got around to installing. The truck starts on the first tick every time, and runs great. At some point, rear helper airbags were installed which work perfectly for towing or heavy loads, with easily accessible schrader valves which exit below the rear bumper. Tires are General Grabber ATX with plenty of life left, and were installed in February 2020. Seat was custom covered at some point, and has a tear on the driver side. Otherwise, all trim, etc, is present. Trailer mirrors were removed at some point, and replaced with aftermarket, with the passenger side having been knocked off by a boat trailer. Drivers side door is dinged, and the passenger side upper cab corner was dented by same trailer.
