5 NEW 20" Weld F-250 F-350 Excursion Wheels (SW/Central Ohio)
For Sale
Wheels and Tires/Axles
  • Wheels and Tires/Axles - 5 NEW 20" Weld F-250 F-350 Excursion Wheels (SW/Central Ohio) - New - 1999 to 2024 Ford F-250 Super Duty - 1999 to 2024 Ford F-350 Super Duty - 2000 to 2005 Ford Excursion - Springfield, OH 45504, United States
    Sold
    Sold
    Sold
The Struggle Bus¯\_(ツ)_/¯
  • Price
    $800
  • Location Springfield, OH, 45504, USA
  • Condition New
  • Compatibility
Make Model Year
Ford F-250 Super Duty 1999 - 2024
Ford F-350 Super Duty 1999 - 2024
Ford Excursion 2000 - 2005
Description:
5 Brand New Weld 'Flare' W139 Wheels/Rims for Ford Superduty Vehicles - F-250, F-350, Excursion
Brand new in the box. I took one out for pictures, the other 4 boxes are still sealed. I don't think Weld offers these anymore. Four of them for your truck, plus a fifth for a 'real' spare instead of the OEM ugly white steel piece of crap.
Weld part number W13909017500.
Rotary forged, heavy duty 8 lug wheels with 8x170mm bolt pattern - will NOT fit a standard F-150.
20" diameter and 9" wide (not including the bead seat).
0mm offset - this means the center of the wheel will sit about 6mm (0.24") further out if you have a 1999-2004 truck or 2000-2005 Excursion (nearly the same) or 34mm (1.34") further out if you have a 2005 or later Superduty truck. The 'backspacing' is 5".
Centerbore is 125.1mm - this means that they are true 'hub-centric' wheels to match the OEM specifications, the wheel sits on the hub itself when mounting and does NOT self-center by the lugs only...ensures a concentric mount.
The center caps on these wheels are large enough that the front locking hubs on older trucks can still be covered. This means that all four wheels can have the center caps installed and not just the rear. This looks nicer.
PM me if you are interested. I am located in Southwest/Central Ohio area.
$800 for all five. Weld makes very high quality wheels and this is well below 50% of original cost. I can't use them, so they need to go.
