Nice condition 8" IPCs for sale. One has ~92k and other has ~140k. See images. Programming can be done via FORScan to match your current vehicle setup. (Note that mileage can only be adjusted upwards via FORScan. FORScan can adjust engine, idle hours upwards/downwards.)
Brand new OEM lens installed on both units. Totally scratch free.
Both units are for the 6.7 diesel (the tachometer is different between the diesel and gas units).
Flat rate shipping (only to lower 48) of $10. UPS
If you're not comfortable doing your own programming, member Livingitup does full programming and I can direct/drop ship the IPC to him for you.
