1991 Ford F-150
For Sale1991 Ford F-150
Price
$4,500• OBO • Trade
- Location Sacramento, CA, 95825, USA
- Condition Used
- VIN 2FTDF15N7MCA60334
- Mileage 210,800
- Engine 8 cyl
- Drive Type 2WD
- Transmission Automatic
- Vehicle Type Truck
- Exterior Color Red
Description:
**If you've seen this ad before, read it again as I've updated the list of things I've repaired**
Up for sale is my 1991 F-150 of ten years. 5.0 302 V8, E4OD 4-speed automatic transmission, rear wheel drive. Single cab, short bed. Lots of upgrades over the years, I will list what I know off the top of my head:
Sept. 2022: Timing cover, timing chain and sprocket, water pump replaced and resealed. Oil and filter changed using
Motorcraft 5w30, FL1A oil filter.
2022: Added a correct era camper shell, no cracks, all glass, comes with key.
2022: Brand new Carlite/Ford windshield replaced at local shop.
2022: Replaced steering wheel with slightly larger one in better condition off a F350, fits/works just fine
2020: Replaced distributor, ignition module, spark plugs, plug wires (PIP sensor failed in distributor, did full tune up).
2018: Took off headlight units, used wet sanding/polishing and clear coat to restore headlight performance.
2017: 3G Alternator from 1996 Mustang - puts out 130 amps, newish belt tensioner and Gates brand belt.
2021: Motorcraft 850CCA battery replaced.
2017: Upgraded 2.5" thick radiator, upgraded fan clutch and 7 blade cooling fan.
2016: Replaced heater core.
2014: R134A air conditioning retrofit / replaced compressor, all lines, condenser, evaporator core, receiver drier.
2016: replaced PCM due to failed capacitor, also repaired 22k ohm resistor in harness to PCM.
2016: LED cluster lights, LED dome lights.
2016: Kenwood deck with Bluetooth, handsfree, microphone, new door speakers, rewired radio connector.
2014: Seat replacement from 1995 F-150 for better quality/condition.
2015: Repainted by MAACO in Rancho Cordova. Body, bed, glass, panels stayed on. Not original color.
2015: Replaced lower intake manifold because of crack. All intake gaskets and injector o-rings replaced.
2016: Replaced steering gearbox, all new power steering hoses and new power steering pump, new MERCON fluid.
2016: Whole front suspension rebuilt w/ MOOG parts; ball joints, axle pivot and radius arm bushings, all tie rods.
2017: KYB shocks all around replaced.
2016: Rear axle drained/refilled and cover resealed.
2016: Added locking gas caps, have one key that works for both.
2016: Driveshaft u-joints replaced w/ SPICER greaseable joints.
2018: Brakes serviced w/ ceramic pads, new rotor/hubs, new NATIONAL bearings, seals and greased/adjusted.
2015: Transmission drain/refill using MERCON V, replaced pan gasket and filter at 150k miles.
2015: 4 pin trailer wire kit and 2" trailer ball / Not trailer brakes, just lights.
2016: Tires replaced, Cooper Discoverer, stock size 215/55 R15.
2013: Starter replaced, O'Reilly remanufactured.
Original: Class V rated bumper for towing
Original: Plastic bed/tailgate liner
Original (As far as I know): Engine and transmission are factory units, never apart, never replaced.
Cosmetically a few imperfections in paint that have been sealed with touch up paint. Headliner has a rip. Carpet has minor stains. Mechanically solid, it runs great. This is by no means a perfect truck but I've daily driven this thing for 10 years and I trust it. Truck passed smog on 9/23/22 and photo proof has been added. Clean title in hand. Tags are valid until April 2023.
Not posting my cell number, just send an email or call my deskphone. You will be ignored if you go straight to low balling the price without even coming to see the vehicle. I do not appreciate my time being wasted. You may only do a test drive if you have a current, non-expired driver's license, proof of CA vehicle insurance and cash in hand to make the purchase. If you have none of those, I will politely suggest you go get those things beforehand.
If the ad is still active, the vehicle is for sale. I will take it down upon being sold.
Asking $4500, negotiable within reason IF you see in person/test drive as described above.
This is a MAYBE but willing to consider a trade for a Honda Odyssey 2007-2010 cloth seats only.
nine 1 six - 5 one four - four zero 2 six
Keywords: Ford F150 F-150 1991 truck camper shell single cab short bed 5.0 302 E4OD
