Cargo Glide CG1000
For SaleAccessories
Description:
Selling a Cargo Glide CG1000 for a Super Duty Crew Cab Short Bed. Unit is in great working order and will include the tie down points that use the side rails to secure cargo. The Cargo Glide will install using generic riv-nuts if you have the, or you can purchase the install kit from Cargo Glide directly for about $40. I will provide the bolts but the nuts are single use. The frame is aluminum and the platform is heavy plywood with a non-slip coating. Located in Millis, about 45 minutes SW of Boston and may be able to deliver within the New England region.
