2004 F350 6.0 XLT
For Sale
2004 Ford F-350 Super Duty
  • 2004 Ford F-350 Super Duty - 2004 F350 6.0 XLT - Used - VIN 1ftsf31p64eb59957 - 83,378 Miles - 8 cyl - 4WD - Automatic - Truck - Blue - West Suffield, CT 06093, United States
  • Price
    $14,000
    • OBO
  • Location West Suffield, CT, 06093, USA
  • Condition Used
  • VIN 1ftsf31p64eb59957
  • Mileage 83,378
  • Engine 8 cyl
  • Drive Type 4WD
  • Transmission Automatic
  • Vehicle Type Truck
  • Exterior Color Blue
Description:
For sale: 2004 Ford F350 Regular Cab, 6.0 Powerstroke Diesel with 83,500 miles. $16,000. Truck was purchased in June 2020 with 77,678 miles (Carfax available). Oil was last changed in October 2021, and has been changed every six months, regardless of miles, beginning in June 2020. The EGR has been deleted which is causing a check engine light for code P0401 - simply means because the EGR is gone. CEL for that code can be permanently turned off with a tuner. This vehicle has recently had the following parts replaced: air filer, fuel filters, coolant filter, two new batteries, new starter, new alternator, rear brake calipers, pads, and rotors, rear hitch (decorative hitch insert rusted in place and couldn't be removed), and column shifter and cable, and new 285/75/16 (33’s) Falken Dynapro AT2 tires with less than 3k miles on them, along with spare tire on a new rim. Truck was purchased with an EGR delete, studded block, four-inch lift, upgraded front manual hubs, 4in Banks Turbo back exhaust, aftermarket touchscreen radio/DVD player, and coolant filter system. To be as transparent as possible, the truck has the following concerns - the bed is rusting and will eventually need to be replaced, the driver seat has a repaired tear in it, and the front right brake caliper seems to be seizing sporadically. I purchased the truck to pull my camper but due to a growing family, can no longer fit everyone into a regular cab truck and do not drive it enough to justify keeping it. PM to discuss
