1951 Ford F1 pickup
For Sale
1951 Ford F1
  • 1951 Ford F1 - 1951 Ford F1 pickup - Used - VIN F1R1RH18494 - 8 cyl - 2WD - Automatic - Truck - Harbor City, CA 90710, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $5,000
    • OBO
  • Location Harbor City, CA, 90710, USA
  • Condition Used
  • VIN F1R1RH18494
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Automatic
  • Vehicle Type Truck
Description:
Project truck, with nearly all parts on-hand + extras.
Bill of sale from original owner and original plates on hand. Do NOT have Title.
Frame sandblasted of all rust and completely painted with POR15 Base coat and UV topcoat in 2011. All new parts listed below also painted with POR15.
3” drop solid front axle from Nostaligia Sids’ dropped axles, painted with POR15. New King pins and bushings installed in spindles. Bushings match machined/ground at local motor shop. New U-bolts, shackles and swing hangers installed for leaf springs. New gaskets and bearings in axle. New master brake cylinders installed and new brake pads in box. New tie rod ends and clamps installed
~2” drop in rear by removing leaf’s from original spring packs. Rear axle rebuilt with new bearings and seals, painted with POR15. New U-bolts, shackles and swing hangers installed. New gaskets and bearings in axle.
Polyurethane sliders added between leaf’s in front and rear leaf spring packs. All leaf’s were inspected, sanded smooth and deburred before reassembly.
Gear box stripped and painted with POR 15. New rebuild kit on-hand but never installed.
Short block V8 from 1974 Falcon was removed from truck and disassembled for inspection and future rebuild. Block is rusty but appears to be in ok shape otherwise and has never been bored out. Heads and manifold in ok shape also. Block is mounted to engine stand which is included in sale.
Transmission (E200?) in OK shape. Shaft is rusted but turns otherwise.
Extra set of doors
Extra set of rear fenders
Extra Hood
Short AND long running boards
Cab air intake tube (accessory item) Missing Seats and slider
Missing motor mounts
Truck is sitting in drive and needs to be towed on flat-bed. 2 front tires hold air.
