Ford Flathead Fan Hub/Pulley custom roller bearing design 1948-52 truck
For SaleAccessories
Description:
Ford Flathead V8 Fan Hub/Pulley.... custom roller bearing design but looks OE factory-built. This item uses the wide pulley and fan belt. 8-bolt fans will bolt onto this hub design. Photos 4 & 5 show internal components, featuring CNC machined steel bearing housing and 3/8" TIG-welded steel flange plate. CNC machined and heat treated 3/4" Summers Brothers 4140 axle shaft. Assembly rotates on two high quality single row sealed ball bearings. Pretty much bullet-proof. Fully assembled and ready to accept your 8 bolt fan and be bolted onto your engine. Never change the oil in your fan hub again!
