1986 DANA/Chelsea PTO - T18/T19 transmission
For SaleDrivetrain
Description:
Chelsea Manually-Activated PTO unit (Cable pull). Pulled off the side of my 1986 F-350 w/ t-19 manual transmission, as the seal between the transmission and PTO was leaking. I have never used it.
When I acquired he truck, the PTO was set up to run a spray pump. I removed and sold all of that stuff, but left the PTO on just in case I ever wanted it. Well, several years in I want to stop the driveway drips and begrudgingly concede that I will never use the PTO - so here it is for sale.
I have no real idea what these are worth, it clearly isn't new. Also, I'm pretty sure I still have the output shaft w/support bearing somewhere. Make an offer.
