1979 Ford 460 .060 over
For Sale
Engine - Complete
  • Engine - Complete - 1979 Ford 460 .060 over - Used - 1979 to 1989 Ford F-150 - Norman, OK 73026, United States
    Expired
    Expired
  • Price
    $8,000
    • OBO
  • Location Norman, OK, 73026, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford F-150 1979 - 1989
Description:
1979 Ford 460 bored .060" = 472 Cubic Inch displacement
Edelbrock 60679 Performer RPM Aluminum Cylinder Heads
Edelbrock 7166 Performer RPM Big Block Ford 460 Aluminum Intake Manifold
Edelbrock 1905 AVS2 Manual Choke 650 CFM Square Bore Carburetor
Sealed Power Pistons H418CP .060"
Hastings .060" Moly Piston Rings Ring Set
MSD Ignition 8350 Ready-To-Run Distributor
Stainless Steel Roller Rocker Arms 1.73 Ratio
Edelbrock 1725 Performer Series Street Fuel Pump 110gph
Ford Performance 429/460 High Volume Oil Pump M-6600-A460
Edelbrock 8866 SBF Victor Series High Performance Street Mechanical Water Pump
All Machine work and build accomplished by Folk's Racing Engines, Machine shop in Norman, Oklahoma
Has only about 2+/- Hours time on it since Overhaul for Dyno runs and Tuning.
Dyno proven 491 HP and 518 ft lbs TQ. @ 5000+ R.P.M.'s. Will easily make over 500+ HP with a bigger Carb.
Built for a '55 Ford F-100 Project that is also for Sale.
Ready to drop in your Vehicle and Run. Will impress.
Everything is new except the Block, Rods, and Crank.Over $9000 invested.
More Pictures, Video and Dyno run sheets available for your review.
Make an offer...
757-621-1094
Chris
