56 F100 parts
For Sale
1956 Ford F-100
  • 1956 Ford F-100 - 56 F100 parts - Parker, CO 80134, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • 1956 Ford F-100 - Numerous parts - Accessories - $3,000 - Parker, CO 80134, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price $3,000
  • Location Parker, CO, 80134, USA
  • VIN 123456789
Description:
I have numerous parts from a recent complete rebuild on a 56 F100.  Truck had previously been restored in the 80's and the work on these parts coincides with the way it was done in the 80's. Not perfect, but good parts to start with.  Some parts appear like new from the last resto and barely used.  Some parts are original 56 parts,  I have the original heater core with the original stampings from 1956 build. I have a good rebuildable water pump w/ C3TE casting. Radiator was good and holding coolant - top tank dented.
Picture Title Part Category Price Part Description
Numerous parts Accessories $3000 56 F100 Parts, more pics available - let me know what you would like to see.  I have too many pics to post at once here.  From Colorado truck so little to no rust. not all parts listed, if there is enough interest I will try to get them all on here. Let me know your interest and we can discuss price - I am trying to be reasonable.
Front drum brake, hub assemblies $50
Wiper motor setup complete 12V - $100
Dana 44 axles - new bearings, new studs, slight wear marks in seal area. L & R axles.
Pair  - $100
Running Boards $300
LF Fender $150
RR Fender $150
Radiator Belt Splash shield OEM Steel $125
Gravel Pan Front Valance $75
Upper Radiator Valance w/ latch $50
Left Inner Fender $75
Right Inner Fender $75
Front brake set up $100
Timing cover 272 Car $100
56 F100 Grille, V8, support  $300
Front bumper and brackets $150
Rear bumper and brackets $75 I
Instrument cluster assy $100
Wiring, complete $50
Tailgate chains $30
272 Oil Pan Front Sump - car  $125
272 Valve covers $20
272 Valley Pan intake $50
272 Intake Manifold 2bbl $75
272 truck 2 bbl Carb $30
272 Exhaust manifolds $100
272 draft tube $10
Steering Drag Link Tube stock length- new $50
Used 5 X 5.5 Lug Pattern $30
272 Car Front Engine Mount $100
272 OE style fuel pump w/canister $30
56 F100 used Radiator $100
56 F100 OE heater core w/ original ink stamping $100
Underbody gas tanks - Pair $50
